I have made sure that all the id3 tags are listed in the advanced properties summary on all of my mp3's. When attempting to sync with the m240 I get the title of the song but never the artist or album. Keeps displaying Unknown Artist. None of my music is protected so that's not the issue. Anyone have an idea on what the problem is. I've used Windows Media Player, Yahoo Search Engine, and even used an id3 tag software to try and fix. All programs I've used to sync display the id3 tags but they won't load to the m240. Help.
I can confirm that the following method works for me (finally):
1. Download and install Mp3tag (I'm using v. 2.48)
2. "Change" or "Add" the directory in which the mp3s reside
3. Make certain you have data for "Artist", "Album Artist", and "Album" (fill in if needed)
4. Select all mp3s and click the "Save" icon (or right-click them and choose "Save tag")
5. Transfer back to your Sansa device
We should admit that a well tagged MP3 collection makes everything from organization to playback easier. But not everyone is fortunate enough to have a perfect music library. There are still so so so many people now suffering lots of a music library with missing or even misspelled song details. If you are the one of them, you come to the right place since I am about to show the solution on how to fix and edit ID3 tags automatically. Fortunately, it's not a big deal to change ID3 tags for your music collection just with the help of Leawo's ID3 Tag Editor. Download Leawo Tunes Cleaner ' Leawo Tunes Cleaner for Mac and install it.
Step 1: Import and Scan Music Library
Run this MP3 metadata editor after installation. As soon as it opens, you could click "Start to clean iTunes" button, or hit "Open music file" to find all songs with incomplete ID3 tags on your iTunes and other music library.
Step 2: Choose songs without ID3 tags for fixing
All songs with incomplete tags will be listed on program interface as the scan is over. You will find categories like "Songs without album artwork", "Songs without artist", "Songs without album", etc. displayed. Then you could enter each category, choose the songs you need to change ID3 tags, then click "Apply" button to download missing tags from online and embed to MP3 files with a click.
Step 3...
For more information, check: How to Edit Music Tags with Music Editing Software
On Sansa M240 go to USB mode and switch to MSC!!!, then copy your music to AUDIBLE. It works for me!!
Solution
First, copy your music over and format the drive, using right-click in Windows Explorer.
Unplug your player and in (the m240) go to settings>enable advanced>usb>enable MSC
Doing these steps will clear out any problem files and the MSC option will make the player display
as a drive in Windows Explorer.
Copy your music to the newly displayed audible folder.
Thats it, it should update the list.
The usb auto detect is the problem, its great if you are using the Sansa software, but for the rest of us, MSC is the best way to use management programs.
Don't rip the CDs with Media Player. Use Sansa software.
The id3-tag can only read by the m240 when the bitrate ist 128kbits.
I tried it...
My m240 can read all ID3-tags!!! Try ist...
With CDex (Free) you can klick on
K, I just have used the ID3-Tag Version 1.0(With a Tag editor) and a bitrate of 128kbits. Now the m240 can read all my ID3-Tags...
I used Tag Version 1.0 and erase all other Versions like Version 2.3 or 2.4!!!
Maybe it helps
I thought about it and I wanna ask you something:
Are you shure, that you picked the right files?
The revonverted files frem CDex where in C:\Documents and Settings\your name\My Documents\My Music\MP3
CDex didn't erase the old files. It creates new files in a new folder.(You can change the folder in the settings)
I am having this same problem and cannot find a solution either. I thought it might of been the method in which I was coping the music over so I tried doing the sync with Windows Media Player. No change. According to the factory literature it supports both V1 and V3 of ID3. Any other thoughts would be appreciated.
Every mp3 I tried to load was over 128kps. However, even after converting them with the software you mentioned to 128kbs it still does not work.
FWIW, I'm loading these to the player using the syn tool of Windows Media Player.
Yes, actually I did catch that they were by default stored in a different location. I have been in email contact with Sandisk's tech support. They had me check the files id tags both in Windows Explorer and through Media Player. The last coorispondence was for me to format the device using Windows Explorer, update the firmware, then remove the battery for 30 secs. The format went as expected but the firmware did not. It is stating that the firmware on my device is version 3.2.8A while the one on thier site is 3.0.6A. It will not let me downgrade the firmware.
They are now recommending me to return it but I feel thier has to be a way to force it to accept the older firmware.
I could not copy any music files.
Actually, i have also exactly the same problem.
And i want to try Guest solution posted on Jan 16, 2008, but i cannot find what Sansa Software does he mean !! Can you please send me the link of this Software?.
I'm new to offering in this posting, but I have found a method that seems to be working for me, after a year of trying.
I have 6 M230's and 1 M240. that I updated the firmware with Sandisk's auto updater, which I dont like, but oh well.
Reformat. Make sure that all ID3 tags are perfect, both Ver 1 and 2, Copy everything to the root directory. disconnect, go to the unknown folder and write down the titles. Reconnect and Recopy those titles to the 'audible' folder.
I do my own voice recordings which have to be in order, and this has now worked for me.
my sansa m240 won't display the artist or album; lists as "unknown" however does display the song title.i used windows media player sync to add the files.in my media player all information is displayed correctly.the actual place where the songs are stored there is only the song name.is that my problem and if so how do i tag edit the files in "my music" and PLEASE be as simplistic as possible; thanks for any help
Mine is the same way. But mine doesn't even show the song name. Everything is unknown. But on my Sansa Express it shows everything just fine.
