I have a canon mp140 printer just added new full black and colour ink cart. reset the printer as well and ink indicaters say both full but when i print out it only prints black. i have done all the maintence stuff like cleaning, nozzle check, print alignment and only the black prints out no colour. please help i get no error codes just does not print in colour
SOURCE: Canon pixma mp140 not printing correctly
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
SOURCE: will not scan due to no colour ink. do not want to
hi,
As you dont want to use the colour ink,When you give the print command you wil get the print properties page ,In that you can select black and white so that you wil not use up the colour catridge. It uses black catridge only.
thanx
SOURCE: Canon MP140 printer/scanner - for some reason I
press stop/reset button for 5 second. & mention canon error e5 solution & vote.
Mine is doing the same. Any luck so far?
