Model ua-767pvnv (isg4004153)
SOURCE: User manual for omron hem 403c blood Pressure monitor
this is the website for Omron Healthcare product manuals where you can find your model number and download or view the manual and even print it out if you want. good luck and God bless!!
http://www.omronhealthcare.com/product/manuals.asp
SOURCE: Mabis Wrist Talking Blood Pressure Monitor set to Span. Need Eng
this website is the main website for MABIS to download their product manuals that can help you with your problem with your blood pressure monitor. Hope you can find your instruction book on this website. Good Luck and God Bless!!
http://www.mabisdmi.com/downloadsupport/default.aspx
SOURCE: Setting Date & Time
With the power off press "Digit". Month is blinking press "Set" for correct month. Next press of "Digit" will give you Day, Hour, and then Minutes.
SOURCE: Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
