There are no codes available for a 6.4 remote on a Vizio Soundbar. Below are the steps to Power Scan the remote control. This will search all codes 1 by 1 until it finds a code that works, or exhausts all available codes.
Power Scan:
1.) With the Soundbar on, press and hold the AUX mode button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press 2 then press STAR (*)
3.) Press the Up arrow button once a second while pointing the remote at the Soundbar. If the code for the Soundbar comes up, it will power off.
4.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Tommy Faust
DISH Social Media Representative
SOURCE: Need Dish 6.3 IR/UHF remote
I found your post interesting, pzednick! What you would need to do is check with the manufacturer, Vizio, for the correct code. We don't have them for sound systems like that; the manufacturer should. Let me know if you have any other questions that I can help with!
tried this a number of times over an hour - nothing ever worked.
If all available codes have been exhausted, we may not be able to get that remote programmed at this time. The link below contains all of our current remote codes, you can use this to check for a code to your Soundbar.
Link:http://www.mydish.com/support/apps/remot...
