When ever I turn on the tv the door will immediatly open,if I put a disc in after a few seconds the door will open.door will not stay shut or play discs.
Try blowing dry air by the disc port, to clean the reading eye(pickup),(get a can at radio shack),prices of today put you to think abouth repair or buy a new one, you decide...good luck
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem. Here's the solution: Put a towel at the bottom of each side of the door by the hinge. Push the door closed a couple of times to bend back the hinges. Remove the towels and you're back in action. Good luck
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD. Change the belt. Try studiosoundelectronics.com or mcmelectronics.com
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Press OPEN/CLOSE on the DVD player
to open the disc tray.
Press numeric keypad ‘1’ on the
remote control for few seconds.
➜ The DVD blue background screen
will appear on the TV.
I have a same problem with different Siemens machine. The dispeser door is opened when the signal comes from control unit. Then wax or bimetall endine opens the door. In my case I can close the box after depowering machine . Immediatly after starting cycle box opened again immedialy.
I posetd request and worry it could be control unit.
regards.
Konstantin
