How to replace both inner and outer tv screens ?
Relativity easy to do yourself, but better if you have some one to help, all you need is a Philips head screwdriver, and the replacement screens, the technical name for them are Lenticular Screen, and Fresnel, one is white, and the other is black.
You start by taking off the screws in the back of the the TV, there are screws along the top, both sides, and there are two on the the bottom right, and two on the bottom left, and there are three on the front by the power and channel and volume buttons. then grab one side and have your partner grab the other, and pull straight off.
IMPORTANT!!!!! DO NOT TOUCH THE WHITE SCREEN WITH YOUR BARE HANDS, IT IS COVERED WITH A POWDER AND CANNOT COME INTO CONTACT WITH ANY FLUIDS, INCLUDING THE OIL ON YOUR HANDS!
There are four bars that hold the screens in, one on top, bottom left and right. to remove the top, left and right you have to wiggle them loose after removing the screws.
The Black screen will go in first, make sure that the smooth side is what you will be looking at when you are done, the white screen will go right on top of it, the rough side of the white screen will meet with the rough side of the black screen.
then put the screen assembly back on, and replace screws.
I hope this helps, if you have any questions, let me know.
