Radio Communications Logo
Posted on Oct 24, 2008
Driver for xp
Head set is not detected automatically in XPP. need driver
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1181
Points
You don't need any driver if ur sound card is ok. Otherwise Check your sound card and driver if any query pl send mail to [email protected]
Dear Sir, We have one IBM x206 8482 I8S Serer. We have loaded Win XPP to this system and configured as Thin Client Server. The Thin Clients hang during the operation. The Thin client Vendor identifies this...
You have a compatibility issue as per your comments and you have no choice but to use the components and operating system that will work with each other. Without drivers you are in deep doo doo and there is no forcing the issue.
1helpful
2answers
Cant access wireless network
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Hp pavilion dv6-2113ax i installed xp but hard disk not detected plz give solution/stata drivers
Hello Shubha,
If HDD not detected then how you install XP. Or this is a secondary HDD.
Normally windows automatically install the SATA drivers no manual intervention needed.
Please clarify.
With regards
Pankaj
I was given an acer travelmate 4230 which used to have vista but now has xp pro. I installed acer bluetooth drivers and software, but a popup tells me that the hardware could not be found. where in the...
On the Acer site, the list does not show a bluetooth.
TravelMate 4230 Series Specifications Part Number: TravelMate4230 TravelMate 4230
Feature Description Model PN CPU RAM HDD Optical LCD LAN OS TM4230-6128 LX.TES06.008 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP PT TM4230-6240 LX.TES06.012 C2DT5500 2*1G 160 8X Supermulti. 15.4 802.11abg XPP FR TM4230-6254 LX.TES06.006 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP FR TM4230-6327 LX.TES06.036 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP ES TM4230-6433 LX.TES06.005 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6434 LX.TES06.011 C2DT5500 2*1G 160 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6704 LX.TFF06.089 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6760 LX.TES06.007 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP ES TM4230-6822 LX.TES06.030 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP PT TM4230-6909 LX.TES06.034 C2DT5200 1*512 120 8X Supermulti. 15.4 802.11abg XPP PT Part Number See models above Processor / Speed Intel® Core™2 Duo processor with Intel® EM64T support:
T7200/T7400/T7600 with (4 MB L2 cache, 2/2.16/2.33 GHz, 667 MHz FSB) or
T5500/T5600 with (2 MB L2 cache, 1.66/1.83 GHz, 667 MHz FSB) Core Logic Chipset Intel® 945PM/GM Express System Bus Speed 667 FSB RAM / Max RAM 512 MB of DDR2 533/667 MHz memory, upgradeable to 4 GB using two soDIMM modules (dual-channel support) Video Subsystem Intel® Graphics Media Accelerator (GMA) 950 with up to 224 MB of shared system memory, supporting Microsoft® DirectX® 9.0, PCI Express® LCD Properties 15.4" WXGA TFT LCD, 1280 x 800 pixel resolution Hard Disk Drive 80GB or higher CD-ROM Drive 8X DVD-Super Multi double-layer drive Battery, Primary 44W 4000 mAh Li-ion battery pack (6-cell) with up to
2.5-hour battery life or
71W 4800 mAh Li-ion battery pack (8-cell) with up to
4.5-hour battery life
(varies by model) Sound Subsystem Intel® High Definition audio support
Two built-in Acer 3DSonic stereo speakers
Built-in microphone
Sound Blaster Pro™ and MS Sound compatible PCCard Support 1Type II PCCard slot Pointing Device Touchpad Peripheral Subsystem 4 USB 2.0 ports, 1 VGA port
Headphones/speaker/line-out jack, Microphone/Line-in jack
5-in-1 card reader (SD, MMC, MS, MS PRO, xD)
Acer OrbiCam™ integrated 1.3 megapixel CMOS
(selected models) Modem 56K ITU V.92 PPT approved, Wake-on-Ring ready Ethernet 10/100 Fast Ethernet, Wake-on-LAN ready
Intel® PRO/Wireless 3945ABG (dual-band tri-mode 802.11a/b/g) Dimensions / Weight 14.09" x 10.43" x 1.15/1.41"
6.09 lbs (with primary battery) AC Power 100-240V AC AutoSensing Adapter
Environment
    Shock
    Operational/Non-Operational
5 G max. pulse / 40 G max. pulse
    Vibration
    Non-Operational
5-27HZ, 0.16" p-p, 2g peak, 27-500HZ
    Temperature
+5ºC - +35ºC / -20ºC - +50ºC
    Humidity
10% - 90% / 10% - 90%
    Altitude
10,000 ft / 40,000 ft Operating System Windows XP Professional with Service Pack 2
Windows XP Home with Service Pack 2
(varies by model)
2answers
I have an Accer Extensa 5220 laptop which came with vista Home Edition. I wanted to down grade the OS to windows XP Pro. After formating the Hard Drive, I ran windows XP setup disk but keeps on giving the...
The problem of your laptop is the hard disk type. because acer 5220 laptop is using a SATA hardisk that automatic detected or supported by Vista. But in the windows Xp you need to download the sata driver for windows xp and save it to the floppy drive. In the beginning of windows installation press F6 to install another device or scsi the windows setup search your floppy drive for the sata driver and install it automatically. If you have cannot fix it just contact me i'm willing to help you
DRIVER
If you are using windows xp,2000 you dont need drive to install just fix the drive in computer properly it wil automatically show you in bios information if your setting is auto detect and after this just restart and your windows will detect the drive with manfactured name dont worry no need of driver for windows xp and 2000
Regards
Balisonu79
2answers
GR-DA20 Problem
NEED DRIVER FOR WIN-XP port 1394
e-mail: [email protected]
Lx 300+ detected by xp but test page fails
hello,
please go to bios setting and change parallel port type spp+epp or epp or normal try to change type and try again.
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
