My GE XL44 stove does not heat to the proper temperature. I set it to 350 and it maybe beeps when it hits 250. I set it at 450, and I usually get to 350, etc. I purchased a separate thermometer to check the stove temp after my food was not cooking as fast as it should. Everything else on the stove seems to operative fine. My stove is 10+ years old.
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
SOURCE: Oven temperature fluctuating
Glowworm, Im assuming your model is a 790.78802500. If your husband is handy with a meter have him ohm out the sensor. It should show around 1091 ohms at 75 degrees or room temp. The preheat is programed so that the manufacturer can get the energy effecient label on the range and what ever perks they get from it. It actually should take around another 10 to 15 minutes to reach the set temp after it shows preheated. You can calibrate the oven by setting bake to 550 degrees. Then press and hold the bake pad again for 15 seconds or until a single beep is heard. Now you can adust temps up or down in 5 degree increments up to 35 degrees by using the slew keys. It will show in the display. Once you have the calibration done, press stop/clear. Catriver...post back
SOURCE: Oven won't heat accurately
Brad, your right on track. But I'd look toward the sensor first (The computer only does what the sensor tells it to do). I'll need the model number to find part numbers to help you further. The model number is on a sticker located on the oven body behind the lower drawer. It'll start with 3 digits then a decimal point the more digits (xxx.xxxxxxxx).
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
SOURCE: GE gas stove
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
SOURCE: Oven temp control not working
you need to calibrate the oven.
go to this web site
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
the second in the list is your solution
I have the same problem with temp was told the control panel and sensors need to be replaced my over is 9 yrs old.
