What kind of power adapter do I need for Planar lcd monitor model s1901d
The brand of the monitor is PLANAR
  • 1,684 Answers
SOURCE:
MicrowaveSvc
  • 9156 Answers
SOURCE: Replacement External Power Supply
So the old power supply doesn't have the output voltage, current and polarity noted on the label? What a ripoff! *grin* Did you look on the case near where it plugs into the monitor? Sometimes that will tell you the voltasge and polarity. Poliarity? Get that one wrong and the monitor could be cooked instantly! But it's usually positive. I found a completed eBay listing that had this info: "the power supply which the seller used to power up this Planar Flat Panel is inventoried as follows: ViewSonic 12V Power Adaptor Model # SYS1126-5012" I looked that one up, and it's listed as 12V at 4.17A. PC Hub has them for $28.62: http://www.pchub.com/uph/laptop/345-19804-2285/AC_Power_Adapter_5V-12V_Others_SYS1126-5012.html Good luck!
Posted on Jan 07, 2007
BoiseLCD
  • 63 Answers
SOURCE: Monitor black screen with blinking amber/green light
Most likely this is thie issue.
I can help you repair this problem by providing you with disassembly instructions and troubleshooting to isolate the issue. From there I will tell you how to DIY, or you can mail the faulty board to me for repair. I actually have spare parts for this monitor on hand and will ship it as soon as your old one arrives at my location. Fast turnaround!
I charge a flat rate fee of $40 for my repair service. That includes return postage. You pay for shipping to me.
I will also accept your entire monitor as a trade in towards the purchase of anothor. I have many working LCD's on hand. Prices for Grade A name brand units (Dell. HP, etc) are as follows:
15" - $50
17" - $70
19" - $90
Trade in credit for your old one:
15" - $10
17" - $20
19" - $30
If you pay the shipping on your trade in LCD, I will pay for the shipping of your new one back to you. Otherwise buyer pays shipping cost for any purchased units,
Please visit my web site, and feel free to call or email me with questions.
Boise LCD
Boise, ID
(208) 891-9117
cjmclellen@msn.com
http://BoiseLCD.webs.com
Posted on Dec 27, 2008
SOURCE: Power on - blank (black) screen
Disconnect the monitor signal cable from PC and switch on your monitor. It should show some logo with Red, Green and Blue colors with a message similar to "No signal". If so, your monitor is working fine. Sometimes if the brightness and contrast is set to zero using controls present in the monitor, it will not show up anything. check wheather somebody set your monitor brightness and contrast to zero. If so incease them. As a last try connect to different PC and check before approaching a service center. I hope this will help you out. :)
Posted on Aug 21, 2009
budmrtn
  • 11361 Answers
SOURCE: How to reset LCd Planar pl17000 monitor
It is not reset problem, more likely to have failure inside the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 17, 2010
  • 44 Answers
SOURCE: on Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
Posted on Jul 30, 2010
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
I Bought two planar dome C3I , i dont have graphic card.
Only the Planar Dome DX2 card..... no other. Planar did this on purpose to sell those cards at 2k each. Now very reasonably priced on eBay, but they'll only work on XP, not W7.
Dec 24, 2011 | Planar Dome C3i 20.8" LCD Monitor
I need a power supply for a 57-c3 monitor. 12v dc 85w
I guess you could be looking for something like these
http://www.coywood.co.uk/lcd-power-supply-flat-screen-mains-adapter-adp-65db-12v-7a-2222-p.asp
http://www.power-adapters.co.uk/12v-dmtech-4-pin-power-supply-adapter-p-4668.html
http://ezlaptopadapters.com/12v-7a-4-pin-power-supply-adapter-p-4006.html
Apr 11, 2011 | Planar DOME C3 20.8 in. Flat Panel LCD...
What kind of power cord do i need for the realsync lcd monitor model #s1901d
the manufacturer would be the place to go for a replacement cord or power adapter.
You can find the contact information on the back of the monitor usually.
Here are some sites that may have the power cord:
1. http://www.12vadapters.com/adapter/power-supply/12v/for-lcd-screens/sceptre-x9g-agama-s1901d.html
2. http://www.replacementpower.com/store/main.aspx?p=itemdetail&item=POWERCORD
May 15, 2010 | Microsoft Realsync 19 8ms LCD Monitor 270...
Backlight replacement
Are you sure it's the backlight? Many Planar LCD monitors have issues with the capacitors on their power supply boards. The symptoms include a power light and no picture, or just a flash of a picture when powering up and then nothing.
The fix for some of these problems is about $8 on new capacitors (Plus shipping).
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3/4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technitian for the work and give them the parts list above. That should work if the failure looks like I described. I've fixed several of these monitors so far. All the problems were related to the power supplies. Same with the Planar PL1700 LCD monitors.
Jan 31, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Power supply pings distributions planar d6015tm
The information comes on the same manual of the planar monitor d5015TM (see as medical monitor)
Sep 12, 2007 | Planar VitalScreen D6015TM (White) 15 in....
Computers & Internet Logo
Alun Cox
