Not heating
See our list of the best electric water heater for 2016. Read our best electric water heater reviews and tips for maximum performance without wasting time..
Electric Water Heater List Reviews waterheaterlist com
Open following links for water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
If you need further help, Iām available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: what years were the Rheem
You can find age of water heater from serial number located on label on side of tank.
Label also shows tank size, and tank wattage and element wattage
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Serial number decoder:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
For example Rheem serial number 0790...
First 2 digits are month 07 July
Next two digits are year 1990
Rheem site does not show 81v40d
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
SOURCE: My rheem water heater doesn't seem to be heating
try setting the bottom 10 degrees hoter than the top could be in short cycle (thatis the bottom calls for heat on the bottom element and set too close so goes back to top and cycles off
SOURCE: rheem electic water heater model 81v52s. switch
It may or may not... if not then check the reset...
Check out this tip...
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
heatman101
