I have tried reading the manuel, but really it's no help. I really need someone to explain it to me.
SOURCE: appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
SOURCE: top stitche is to tight and bottom stitche is to loose
Meaning you have adjusted the tension for the top thread as well as the bobbin?
Use two distinct colors of thread - one for the top and one for the bottom.
Thread the machine with the presser foot up.
The two threads should meet in the middle of the stitch with neither obvious on the opposite side of the seam.
Set the top thread tension to 4 and adjust the bobbin as needed.
SOURCE: Suddenly my brother xl-2220 is
totally rethread, and do this test, rethread with the presser foot up, pull the thread it should feed smoothly, now lower the presser foot, pull thread, it should barely move. This will seat your thread in the tension discs, Also, don't be afraid to change your needle often.
SOURCE: tension problem
.There is a little screw attached to the bobbin carrusel. You can try
to turn it just a little bit. The reason is that this carrusel gets
loose after a while.
Clean and oil your machine at least monthly.
Hope something helps!
