I have BigBen Balance Board and I can not find adequate silicone skin. The problem is that all skin I have found are designed for Nintendo Balance board which is little lower than Big Ben and it is little curved on all four sides. When I put such silicone cover it does not fit easily and pins on corners part do not go in the holes around weight buttons. Does anyone know where can I find fully compatible silicone skin for my BigBen Wii Balance Board. Thanks in advance.
SOURCE: wii fit balance board
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guideto fix the problem yourself. This DIY guide will show you step by steppictures to fix the problems. yourself without any technical knowledge.
SOURCE: wii balance board weight differently after put on a wii board sk
Sometimes the silicone skin can have an effect on the Wii Fit Balance Board if it gets pinched. Make sure that it is not interfering with the the total movement of the top portion of the Wii Fit balance board and the space between the top and the middle of the unit. If there is any obstruction, refit the skin on the balance board.
SOURCE: Jillian Michaels won't allow Wii Balance Board for weigh in
Actually, I had the same problem and discovered that you have to have the wii remote in your hand and that you must push the A button once you're on the board. Otherwise it just keeps telling you that you're moving too much.
SOURCE: The big ben balance board
Did you find a sync button under the battery cover? I mistook the big button for sync button. But the sync button is a small button under battary cover. Also the board should be not further than 1 meter from you Wii.
Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
Insert a Wii Balance Board compatible game into the Wii system.
Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
Turn the Wii Balance Board upside down.
Remove the battery cover under the balance board to reveal another sync button.
Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
1.
disc in the Wii console.
2.
Use the Wii Remote to select the Disc Channel
from the Wii Menu, then select "Start" to begin the game. Press the A
Button to bypass the wrist strap screen.
3.
Open the small SD Card slot cover on the
front of the Wii console.
4.
Remove the Battery Cover on the bottom of the
Wii Balance Board.
5.
Press and release the SYNC button on the Wii
Balance Board. The blue light on the board will start blinking.
6.
Press and release the red SYNC button on the
Wii console while the blue light on the board is still blinking.
7.
The blue light will stop blinking and stay on
steady once the synchronization is complete
Click here to download repair guide
1.
2.
3.
4.
Wii Balance Board.
5.
6.
7. The blue light will stop blinking and stay on steady once the syncronization is complete
