Question about Innovage 1604007 Corded Phone
INNOVAGE 1604007 The phone speaks on incoming calls,can it be changed to ringer?Should phone co be called?,phones do not ring on incomig calls on any of my lines?
    New Friend:
    Problem Solver:
  • 6 Answers
Press SET. Press UP to select Set 8 Speech. Press Set again to confirm. Screen will show default setting SPEECH ON. press Up or DOWN to select ON/OFF. Press SET to confirm newetting
Posted on Dec 30, 2009
    New Friend:
How do you change the ringer ton?
Posted on Jan 04, 2010
SOURCE:
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
I use the handset lifter for the phone I have (Polycom SE-225). When am sitting at my desk neat the phone, I speak anything above a low normal into the bluetooth headset, like when I am laughing or people...
Unfortunately no. The phone ringer has to be a certain volume for the lifter microphone to pick up the ringing vibrations. If you put it to low, you will not be alerted to the incoming calls. When you're at your desk and can see the incoming calls, maybe then you can lower the telephone ringer volume for some relief.
Good luck from Headsets Direct!
Jan 03, 2011 | Plantronics Voyager 500A Deskphone Adapter...
How to turn the music off when a call come in.
More information is needed.....But, it sounds like you are trying to turn off/change the ring tone of an incoming call. It's easy to do, I left you a download link for the manual below.
Here are the steps to change your ring tone:
1. Leave the hand-set on the cradle
2. Now just press the flash key repeatedly to scroll through all the different ring tones or to turn it off.
If you need the manual for future reference, you can download it from the link below -- It was made and uploaded by me, so it is safe....
http://www.megaupload.com/?d=8EIJ8RH3
Hope this helps --WICC--
Jan 24, 2010 | Innovage 1604007 Corded Phone
INNOVAGE 1604007
See #11 in the manual...try turning the spy prevention off.
Oct 23, 2008 | Innovage 1604007 Corded Phone
Why is my phone ringing?
Your Handset has been programmed i guess by mistake to be in the same ring group as the main receptionist for C0-01 . Use Google for programming manual to make changes.
www.heymot.co.uk
Oct 17, 2008 | Panasonic KX-T7633 Corded Phone
Innovage (1604007) Corded Phone
Here is the fix for that problem...
1st click the set button on the bottom left of the keypad. Press the "up" button (located to the right of the the keypad) until you get to option number 7 IPP. Click the set button again (so you can change the settings for that option) and press the down button to turn off the option. Click the set button one more time and finally press the delete button to get out of your settings mode. No More beep, beep, beep......
Hope This Helped--WICC-
Feb 07, 2008 | Innovage 1604007 Corded Phone
Touch-panel/caller ID speaker phone
My phone did the same thing. It was the spy prevevtion function. pressing (#) for over 2 seconds. turned "SPI OFF". worked OK.
Dec 31, 2007 | Innovage 69420210126 Phone
Simply want to turn ringer off at my phone for external incoming calls
How do you want to be notified? How do you determine if a call is for you? Does an operator answer the call and transfer it to your extension? If so, you just need to change programming for your phone so it does not ring for incoming calls. It would still ring if a call is transfered to you. Programming is changed in the phone system, not the telephone. Your phone can be used on different Nortel systems that program differently so you need to find out which system you have and locate the manual for that or pay a local installation company to make the changes.
Nov 08, 2007 | NorStar T7316E Corded Phone
How to change ring tones
To change the ringtone, just keep tapping the flash button. It will turn the ringer on and off, also it will go through all the different ringtones.
Aug 27, 2007 | Innovage 1604007 Corded Phone
Innovage 1604007 Corded Phone Logo
206 people viewed this question
Top Innovage Lands Phones Experts
spiritsoul
Level 1 Expert
Damen Wong
Damen Wong
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
