Here is the OBD2 emission system drive cycle test procedure.
Engine coolant temp must be below 70c (158f) before starting the engine for either the first or second trip
The fuel level should be less than 1/2 full
First trip:
Start engine, idle for at least 1.5 minutes
Drive 3 minutes, hold b/f schdl: 1.5-2.0 msec, selector lever "3rd" eng rpm 1,800-2,000 A/C switch:ON Hold the recommended b/f schdl range. Allow road speed to vary as necessary.
Drive at 55-65 mph for 1.5 min b/f schdl 2.0-3.2 msec, selector lever "5th" Engine rpm 2,200-3,000
IGN "off" for at least 10 seconds (not more than 5 min)
Dive at 50-60 mph for 3 minutes Selector lever "4th" keep engine speed above 3,000 rpm Allow speed to vary if necessary. Do not decelerate for more than 3 consecutive seconds. A/C switch ON.
Drive at a steady state cruise of 53-58mhp b/f schdl more than 1.8 msec selector lever "5th" eng rpm 2,400-2,600
Downshift to "4th" and decel more than 5 seconds without breaking, then idle for 1 minute.
Drive two minutes b/f schdl less than 2.0 msec Accelerate to 41 mph, decelerate to 34 mph, accelerate to 41mph. Do not completely release the accelerator. A/C switch off.
Idle 1 minute in park or neutral
Drive two minutes Steady state cruise at 31-44 mph. Selector lever "4th" A/C switch OFF. Hold the accelerator pedal as steady as possible. Allow speed to change if necessary.
End of first trip. Turn the key off the begin the second trip.
Second trip:
IGN "off" add four gallons of fuel
I especially like the part where they want you to add four gallons of fuel. Not three gallons, not five gallons, four gallons. Gotta love those Nissan engineers. ...and of course they state that if the trace is not followed exactly (i.e. you botch the acceleration/deceleration) you have to start all over again from scratch
