It works, but I get the following error message every time I open the program. "Unexpected error. Could not download the required files for update. The application will NOT be updated. Try again later." When I try to update the software nothing happens (it says my files are up to date). Any ideas?
SOURCE: Transferring Video to Computer Major Problem
The Flip Video Camcorder is a portable, easy-to-use solution for creating and sharing high-quality home movies. Flip Video is the ideal choice for capturing everyday moments that happen anywhere, and sharing them with family and friends everywhere.
Flip video camcorder isn’t without its drawback. Although you might find the recorded mp4 video files compatible with iMovie and QuickTime on Mac, they just fail you every time when you directly import them to iPod or iPhone. Flip video converter for Mac is able to compress flip video to different file sizes with different resolution, frame rate and bit rate to be exactly compatible with iPod, iPhone, Blackberry, etc.
Besides Youtube and Mysapce, Flip video converter for Mac provides potential Podcast production assistance to let you post up your own video to iTunes. with the software, you can rip audio either from Flip Ultral video or Fip Mino video and convert to mp3, ogg, aac audio format, you can also convert flip video to flv, asf, 3gp, mpeg-4, mov, m4v, mpg, avi, wmv for your specific project
SOURCE: cannot send video by email (flip share)
When I upload my videos I can't play the video when I click on the play button. My daughter can watch the video on her Mac. Is the problem my PC and if so how do I fix it?
SOURCE: My Flip video Error code 17,2 - won't connect to software
Tech Support at least found a solution to upload.
Remove the battery from the Flip, then insert into PC. You may have to manually uninstall the driver association during the previous hardware failures (Use Control Panel, Device Manager, Hardware, USB Devices - then right click the yellow ? icon to uninstall).
If you are lucky, you will now see your videos. Upload to your PC, then insert the battery pack while connected. Unplug the Flip, wait 10 seconds, and try again.
If this solves your problem, charge by connecting to a PC for 6 hours to make sure you have a full battery charge.
SOURCE: i plug in my flip
have you installed the Flip video software? Should be pre loaded on the camera but sometimes you have to install it manually. "My Computer" --> "Flip Video Camera". There should be a .exe file there that will install the software, then you can manage your videos. If you have already done this then I would check the USB connection and contact Cisco Support.
