Can fix if I keep getting a black screen
Hello
You can prevent the computer from going into sleep or hibernation mode by going to the CONTROL PANEL - POWER SETTINGS.
Once here, change the settings to High Performance.
You can also go into advanced properties and manually change all of the settings - including when the hard drives go to sleep (I set this to NEVER), when the monitor will go to sleep (again, I set to never).
The problem can be correct in the control panel power options..
select hig performance as the preferred plan,
click change plan settings
change both sleep options to never>>
this is caused by a corrupted display settings in the registery and needs to be reformatted or restored using the factory restore disc to fix the problem. the above solution will work just remember to put your system to sleep manually and turn of your monitor.
