I got a conection showing up for wireless that sayes it is conected i cant get accesses it sayes windowes can not connect to the wireless network and that connection askes for a network key? i tryed to plug it into the internet with a hard wire cable the light in the back that showes that it is working lights up but nothing else showes up any ideas
When youclick Refresh network list, then Choose yourwireless network and then click Connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network, configuringthe wireless router and configuring the wireless card in the laptop/computer,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: internet connection
HI,
Press the FN+ f2 key on the keyboard and switch on the wirless antenna .
Thanks
Proton
SOURCE: can not conect to internet after Microsoft July update with xp computer
Since when did you install the update, if you can uninstall it please do so, or you can try to do some system restore.
SOURCE: can't conect to the internet (wireless or cable)
access your router with following link
http://192.168.1.1 or http://192.168.0.1
if you have belkin router then http://192.168.2.1
type user as "admin" and password as "admin" or blank or "password"
then go to interent settings then check dhcp is enabled? if not then enabled it.
then go to your computer network adpater tcp ip settings then set ip addreses getting automatically.
SOURCE: HOW CAN I GET INTERNET CONECTION IN MY LAPTOP
I assume that you have loaded all the drivers for you laptop from
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D410&os=WW1&osl=en&catid=&impid=
If you need the manual,
http://support.dell.com/support/edocs/systems/latd410/en/index.htm
The instructions for connecting to a wireless network is under the "wireless local area network" instructions.
SOURCE: latitude d400 doesn't show wireless networks
Chcek if there's a wifi switch and if it's turned on. Try going to a wifi hotspot and see if your system can detect any wireless networks. If not, uninstall and reinstall your wireless drivers.
