Sony VAIO VGN-N320E Notebook Logo
martin Posted on Feb 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
L key shows 3 instead
Little icon chain 1 light on
David Soto
Level 2:
  • Expert 414 Answers
  • Posted on Feb 09, 2012
David Soto
Expert
Level 2:
Answers
414
Questions
Helped
193735
Points
758
You have the Num Lk key set to type numbers. All you need to do us press the same key again and the numbers lock will be off.
1helpful
I replaced the fuel pump on 2005 Colorado. it shows an anti theft icon and will not start. what can I do?
1. Attempt to start the truck by turning the key to the Start/Run position. The passlock icon may be illuminated or flashing. Try to crank the vehicle.
2. Release key to the ON/RUN position (not the ACC position or OFF)
3. Allow the vehicle to sit with key in the ON/RUN position until the passlock security icon turns off. This could take as long as 12 minutes
4. When the light goes off, turn key to OFF position and keep the key in the OFF position for no less than 30 seconds.
5. Go to #1 and repeat for four cycles or until vehicle starts.
Error code E002
  1. Press the User Mode key. (Looks like a little man head. Some people call it the function or additional function key.)
  2. Press 2 and 8 on the keypad at the same time.
  3. Press the User Mode key on the control panel.
  4. COPIER Icon
  5. Press the Function icon
  6. Press the Clear Icon
  7. Press the Err Icon
  8. Then ok.
  9. Exit
  10. Power off
  11. Wait 1 min.
  12. And Turn on machine
What other chain can i use on a stihl 025
You need to know three things about your saw as to what chain will interchange....1. Pitch of the chain. 2. Guage of the guide bar. 3. Number of chain links.
Your little 025 Stihl wil probably have an .050 guage and a .325 pitch. The standard guages for small saws are .043, .050 with .058 and .063 being reserved typically for the larger displacement saws.
The pitch is the length of three links, divided by two and the number of links is kinda self-explanatory. (The 025 USUALLY is set up for the .325 pitch.)
Any chain that matches the three measurements for your respective saw should interchange. Hope this helped instead of adding to the confustion......
Key icon is showing on dashboard and car will not start
the car is not recognising the key, try first to replace the key battery, also if you have another key try to use it.
I can't start the engine. The battery is almost fully charged. I need to turn the key for about 3 or more times to start the engine.
If you turn key to START position, what is the sound, is it;
1. no sound at all means maybe starter problem.
2. only heard Tik sound means starter problem (you can add relay but it will still happen in future)
3. crank sound but not start means battery weak.
You can also try to move gearshift to N instead of at P position before turn key to START. if it work mean your car safety switch at gearbox not know which gear you're on.
3helpful
Some keys show numbers instead of lettes
You have the numbers lock on, all you need to do is press the Num Lk key down and the little icon light 1 should turn off and now all the letters will show letters only.
Have a good day.
2helpful
What do; the four little lights below my keyboard mean? One is the battery, one is the internet, but the other two? Especially the third from the lert with the icon that looks like a stack of pancakes?
The icon that looks like a stack of pancakes is the one for the hard disk drive and the indicator with the icon flickers or lights whenever there is hard disk activity. The reading / writing of large files will cause the hard disk drive activity indicator to light almost steadily until the file reads / writes have completed. There are two icons that look like little padlocks. One has the character 1 and the other has letter A. The padlock icon with the 1 in the middle is the indicator for NumLk or Numeric Keypad lock. Pressing the Fn key and the key with NumLk on it turns the Numeric Keypad on and off. When it is on, pressing the keys for UIOJKL will enter 456123 facilitating entry of numbers with the keys arranged as a keypad along with the top row of keys 789. Finally, the padlock icon with the A in the middle is the Caps Lock indicator which lights when the Caps Lock key is pressed allowing subsequent presses of letter keys to be capitals without having to press the shift key. Pressing Caps Lock a second time turns off the Caps Lock. Similarly, a second press of Fn and NumLk turns off the NumLk.
1helpful
Sharp 5316E how to enter code
Did you mean the account control code ( 3 digits code ) ? If you forget this code, either you disable the account control mode or change the old user accounts. Here's how :
1. Enter the USER MODE PROGRAM by pressing and holding the Light key indicator ( the white half circle ) at the bottom left of the machine.
2. After the all the lights at the panel goes off ( except the quantity copy display, it will show 3 lines ). press 10 with the 10 key and START, change the value from 1 to 0 and press START again to save the value. THIS IS DONE TO DISABLE THE ACCOUNT CONTROL MODE.
3. If you want to show the user account and cange it to a new account, repeat the above step but enter 12 instead of 10 and press START. It will shows you your current user accounts ( up to 20 accounts ). If you still want the old user account, remember that code and press the light exposure key 1 more time withou holding it.
4. If you want to change the old user accounts, after the machine shows you the user acccount press START and input the new 3 digits code and START again.
LaCie icon won't show up on my mac desktop
1. A. Yes.
2. A No.
3. A. Replace the LaCie
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
