Dell Inspiron 8600 Notebook Logo
A
Anonymous Posted on Feb 09, 2012
Error code: 3600:0123
Battery charger
1helpful
My Eliminator Intelligent Battery Charger, now flashes 000 regardless of what battery I put it on. Can I reset it and get my charger working again?
you can try to reset your charger and get it working again:
Check the battery voltage: Use a voltmeter to check the voltage of your battery. If it's below 3 volts, it may be too low for the charger to detect. In this case, you may need to use a different charger or replace the battery.
Check the connections: Make sure that the battery terminals are clean and securely connected to the charger. Loose connections can cause voltage drops and prevent the charger from detecting the battery.
Check the fuse: If your charger has a fuse, check if it's blown. A blown fuse can prevent the charger from working properly.
Reset the charger: Unplug your charger from the power source and remove any connected batteries. Wait for 10 seconds and then plug it back in. This should reset your charger and clear any error codes.
If none of these steps work, you may need to contact customer support
Sharp MX-3640N A3 Color Laser Multifunction Printer. Error service code: C1-14.
Question edited for full 'make model (what it is)'.
Error Codes > Sharp > MX3610N > Code C1-14 - PrintCopy .info
https://printcopy.info > code=C1-14
Code: C1-14 · Description: Main charger trouble (Color) · Causes: The main charger unit (CMY) is not installed properly. There is an abnormality in the main ...
SOLVED: Error code C1-14 - Sharp MX5001N - Fixya
https://www.fixya.com > ... > Sharp
Apr 9, 2019 - Code. C1-14 · Description. Main charger trouble (Color) · Causes. The main charger unit (CMY) is not installed properly. There is an abnormality ...
How to remove error code C1-14 For Sharp MX-2501N - Fixya
Sept 5, 2019
Questions & Answers for: sharp error code c1 14 - Fixya
Nov 16, 2019
SOLVED: Sharp mx 3100n C1-14 error code - Fixya
Dec 12, 2020
Error code C1-14 - Sharp Mx-2310u Color Copy/print/scan
Apr 8, 2013
More results from www.fixya.com Missing: 3640 ‎' Must include: 3640
Sharp MX-2630 Error C1-14 - Copytechnet
https://www.copytechnet.com > ... > Sharp
Apr 27, 2019 - Error Code Sharp MX-2630 Error C1-14. If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to ...
Sharp MX2640 error C1-14
Jun 20, 2017
Error Code C1-14 on MX3100N
Jul 23, 2011
MX-6240, 7040 (Polaris) with error code C1-0X ...
Jul 17, 2015
More results from www.copytechnet.com Missing: 3640 ‎' Must include: 3640
Codes erreur SHARP - Sharp Photocopieur
https://www.photocopieur-sharp.com > codes-erreur-sh...
C1. C1 10 MAIN CHARGER TROUBLE (BK). C1 14 MAIN CHARGER TROUBLE (COLOR). C4. C4 00 PTC TROUBLE. E7. E7 01 MFP IMAGE DATA ERROR. E7 03 HDD TROUBLE.
Sharp MX-2310U, MX-3111U (SERV.MAN68) Technical Bulletin
https://servlib.com > Sharp > Printer
MX-2310U, MX-3111U (serv.man68). CCE-1425 MODIFICATION OF TROUBLE CODE C1-10 or C1-14 DUE TO DEFECTIVE MC PWB - Sharp Copying Equipment Technical Bulletin ...
Exide System 3000 Charger. Power up good, AC LED on. Plug in battery (24V for forklift), Daily LED on, then slowly fades out. Charger output = 0. Pushing Daily or Equalize button does nothing.
You can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassemb ly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
2answers
I have a cen-tech 63873 battery charger and it is flashing EF02 on the screen. It will not do anthing but flash.
An EF-02 flashing error on the Cen-Tech 63873 battery charger means that there is a short circuit.
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
I have an error code of FOO ?
Joseph, No F00 maybe contact company. Digital Battery Charger Error Code Explanation Chart. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ERROR CODE DESCRIPTION REASON/ SOLUTION F01 The battery voltage is still under 10V (for a 12V battery) or 5V (for a 6V battery) after 2 hours of charging. Could be caused by trying to charge a 6V battery on a 12V setting or charger, or the battery could be bad, have it checked or replaced. F02 The charger cannot desulfate
the battery. The battery could not be desulfated, have it checked
or replaced. F03 The battery was unable to reach the "full charged" voltage. Could be caused by trying to charge a large battery or bank of batteries on too low of a current setting or the battery may have a shorted cell. Try again with a higher current setting or have the battery checked or replaced. F04 The connections to the battery
are reversed. The battery is connected backwards. Unplug the charger and reverse the connections to the battery. F05 The charger was unable to keep the battery fully charged in maintain mode. The battery won't hold a charge. Could be caused by a drain on the battery or the battery could be bad. Make sure there are no loads on the battery. If there are remove them.
If there are none, have the battery checked or replaced. F06 The charger detected that the battery may be getting too hot (thermal runaway). The charger automatically shuts the current off if it detects the battery may be getting too hot or the battery may have a shorted cell. Have the battery checked or replaced.
FAQS
Schumacher XP2260 Owner Manual
XP2260W Schumacher Portable Power 1200 Peak Amps
Why does battery charger blink twice no matter where its plugged in?
You may have a failing capacitor on the secondary side of charger power supply circuitry. The output voltage will be low or have a lot of ripple; this would cause the error detected. Pictured below is a bad electrolytic capacitor next to several good ones (this is not from a battery charger). Notice how the top is bulged upward instead of being flat - it indicates pressure caused by the capacitor burning out.
There are other failures that could cause this error code, but this one is highly probable.
Error code eo1 on radio charger
Best Guess: Bad Battery. If it does it with known good batteries then there is probably a fault within the charging unit itself.
I’m happy to help further over the phone at https://www.6ya.com/expert/jason_60e0f57ba319f3f6
1helpful
Lenovo g550 orange flash 3 times
3 orange flashes means flat battery. If you have a faulty charger or charger socket on the laptop then the battery wont charge or power up with just the charger connected.
Look here:Lenovo
32helpful
Black and Decker Battery Charger
Fault Codes Meaning of Fault Code F01 Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load. F02 Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair. F03 Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual. F04 Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual. F05 Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation. F06 Reverse Polarity F07 Alternator Output is Out of Typical Operation Range
Operation Codes I=I=I=I Battery Reconditioning - (The letters DES will display for the first three seconds) I-I-I-I Alternator Voltage Check OOO Charger Standby FUL Battery Fully Charged
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
