I have had the set for 6 months...and all of a sudden the other day...both phones show "power failure" when I try making a call. That is still the status... What is up? I have had both of them on their independent chargers... It does not make sense to me how both of them can have power failures at the same time...
SOURCE: VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
SOURCE: is there a manual I can download?
http://www.vtechphones.com/docMgt/public/art/22050/ia5854_manual.pdf
my vt phone is lock and need to unlock it help
