Hi
I own a Zenith DTT900 Converter, along with a briefcase full of
universal remotes. Most of the remotes I own do not work with the
converter, but here are the codes and remotes that DO work that I know
of: All are programmed under the satellite receiver button.
Phillips PM6225 6 Device Consolidator--Code 267, which is listed as a Zenith satellite receiver
Radio Shack Model 15-135 HDTV Pro Remote-- Code 01414, which is listed
as a DirecTV satellite box code, as well as an LG satellite box code
Radio Shack 8-in-1 LCD Remote Model 15-100--Code 01414, which is similar to the model 15-135.
Zenith 6 Device Universal Learning Remote Model ZN620--Code 267, similar to the Phillips remote listed first.
thank you
On a One For All Universal Learning Remote URC-8820, the code that
operates my Zenith DTT901 is 1415 on the cable button. This is the code
for LG HDTV Decoders. If you don't have the same remote, I'd look up
the code in your remote's book for LG HDTV Decoder (also listed under
"Video Accessories" in my remote's setup book.)
All except one of the key functions work to control the Zenith box by
setting that one code on my universal remote, including zoom, info,
programing menu, recall, mute, channel, volume, etc. The only function
that I may have to program manually is Simple Guide.
Hope this helps
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Appreciate your quick postback. Unfortunately not all universal remotes uses the same set of codes. No worry then, at your convenience, if and when.
Cheers.
You may try 401
http://www.xdiv.com/remotes/
Please give me the make and model no. of your remote so that i can give you the code.
I will be waiting for your reply.
Unfortunately, the remote is in Florida. I will have to wait until I am down there to get the make and model number of the remote. I was under the impression that the code went with the unit
( tv, vcr, etc) and that all remotes used the same code for the unit.
