Question about Lanier Audio Players & Recorders
Interchangeable accessories for Harris Lanier Transcriber VoiceWriter 150 & 250
Are all harris lanier transcriber equipment accessories interchangeable between models? I have 2 Lanier voicewriters: 150 and 250 and they share the same foot pedal model: LX-055-5. Does this mean that I can use any harris lanier foot pedal and it will function expectantly? If this answer is no, does anybody know of an adaptor that I can purchase that enables me to interchange? Thankyou.
5 Suggested Answers
SOURCE:
  • 7 Answers
SOURCE: Lanier Transcriber unit will not play
Most likley it is a bad motor or a broken belt. There is a seperate motor or FF and Rewind.. If the motor is bad it is likly that the motor control circuit board is bad also (motor shorts and takes out the board also). If there is no "click" when play is selected it could be the play solenoid is dirty and not engaging. I have repaired thousand of these units through the years and in spite of these issues they were a great sounding unit.
BTW this is true for the VW-210, VW-260, p-139 and simular units.
Posted on Jul 16, 2008
SOURCE: I have a Lanier Voicewriter
Pull up Job List, find the dictation and assign it to a specific person. Then you can listen to it. It will beep unless your feet are on the pedals.
Posted on Jan 12, 2011
javer821
  • 207 Answers
SOURCE: I HAVE THE LANIER VW 110 TRANSCRIBER; I PLUG IT
Hello is possible that your power supply is bad or may be just the jack on the unit you have two options you can Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem or try a new power supply at http://www.tvps.com/Products/Lanier-APS-160-Desktop-Power-Supply---New__LA-APS160.aspx
Posted on Apr 15, 2011
t_d_hofstett
  • 1406 Answers
SOURCE: Where can i get an adaptor for Harris Lanier Transcriber VoiceWriter 150 & 250. Im talking about playing a mini cassette on a large cassette machine. Thnx
I don't think that's possible, the minicassette won't fit between the spool spindles. You may be able to use a minicassette player, and route its output to the full-sized cassette recorder, though, or to a little transmitter that broadcasts to a matching receiver in the full-sized cassette player.
Posted on Aug 12, 2014
Where is the recall button located on the Lanier VoiceWriter 160 transcriber?
It is under the flap located directly under the keyboard buttons. It is a slide switch and you can adjust it for a little recall or a lot of recall.
Oct 13, 2014 | Lanier Audio Players & Recorders
Aug 12, 2014 | Audio Players & Recorders
How do I erase the tapes on a Lanier VW-210
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Jan 13, 2012 | Lanier Audio Players & Recorders
I have a Lanier Transcriber Model V W-210. Today the fast forward and the reverse did not work. I could hear a motor sound, but the tape did not advance or reverse. The "listen" worked, as did...
This unit most likely has a broken rewind/fast forward rubber belt. This is a very common problem and is easily fixed if you can acquire a new belt. Any place that services Lanier equipment should be able to easily fix this problem.
Sep 20, 2011 | Lanier Audio Players & Recorders
I HAVE THE LANIER VW 110 TRANSCRIBER; I PLUG IT IN AND GET NOTHING. COULD MY POWER CORD BE BAD?
Apr 14, 2011 | Lanier VW-160D
I have a Lanier model VW 260 transcriber. 1) how do I erase old letters? and 2) does it have the auto rewind feature? (when I release the play pedal it goes back so many seconds) Thank you. Laura...
Hello Laura
Yes your unit has the option for erase Just hold down the REW and Telephone button at the same time make sure that you really want to erase the tape and the auto back space when you relase the foot pedal is the button located inside the front door they called Recall thats for adjusting how long you want to go back. thanks and good luck, if you ever need any type of accssesory please go to at www.tvps.com for large selection for professional Transcription units service and accessories http://www.tvps.com/Departments/Dictation-Accessories/Headsets/Cassette.aspx
Nov 24, 2010 | Lanier VW-160T
Just started using Lanier model VW 260 transcriber for work. The counter display does not change. The top of the screen shows "Inst", "Length", "Unit No.", Total Units", and "Level". The only numbers it...
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Nov 13, 2009 | Lanier VW-160T
Lanier VW 210 transcriber beeps like it is at the end of the tape
There is a sensor that detects tape movement. Unfortunately they do go bad and will probably need to be replaced.
Nov 26, 2008 | Audio Players & Recorders
50 people viewed this question
Top Lanier Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
