Hi Edward:
In dashboard, your THEFT warning light is blinking? If the answer is yes, your antotheft system is activated and will need restart and resynchonized. This occurs when battery is disconneting or other un-authorized key is used.
Vehicles equipped with Vehicle Theft Security System (VTSS) are protected from vehicle theft andunauthorized entry. VTSS system monitors vehicle doors, hood, liftgate and ignition. If an attempt is made toenter or operate vehicle without proper disarming of system, vehicle horn will sound, headlights, taillights andparking lights will flash, and engine will be prevented from running.
VTSS system arms when ignition is off, vehicle is exited, door is locked using power door locks and door isclosed. Alternatively a remote keyless entry transmitter can be used to arm system. A security light on panelwill flash for 15 seconds to indicate system is arming. At the end of 15 seconds, if no door, hood or tailgate isopened, system is armed.
If alarm is triggered, horn will sound for 3 minutes, and lights will flash for an additional 15 minutes. If hornsounds 3 times when either front door is unlocked, vehicle has been tampered with (tamper alert). If doors arelocked manually or with key, system will not arm (manual override). If an unauthorized entry does occur, VTSSsystem signals Powertrain Control Module (PCM) to prevent vehicle from being driven. PCM reduces injectorpulse width to zero, causing a start and stall condition.
System can be disarmed with the keyless entry transmitter, or by using key to enter vehicle. In both instances, if alarm was activated, vehicle alarm will be terminated. If battery is disconnected and reconnected, alarm will beactivated and it will be necessary to disarm system as indicated.
Please, send us some email account to send you this procedure in PDF format file.
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
