Black screen cant get menu
Hi Tracy..., last month my ipad got black screen also, all i have to do is.. I open it
slowly and carefully pull-up the touch screen,then i remove the LCD and at the back of LCD you can see the black plastic cover, carefully remove it,then when finish removing it, at left side there is flix ...that is the connection of backlights...
if you see that is broken that causes you the ipad turn black screen, all you need is to get a soldering iron and a lead then fix that 9 connections of flix one by one ..and after that, all parts that you remove return it carefully and restart your ipad..and you have your ipad now back to normal
