I connected my ipod to my computer to sync songs/charge it; it failed to sync the songs and it also didnt charge at all after i disconnected it the ipod was stuck on the screen that says " OK to disconnect" i reconnected it and it went back to charging screen after i disconnected it again it restarted and has been on the loading screen for awhile...
SOURCE: OK to Disconnect
Fixed it myself! Reset by holding down Menu and centre button until soft reset complete. All working fine now.
SOURCE: ipod keeps disconnecting
what it can sync but you cant select songs manually? if that is so check if utoo sync is on. if using the new itunes 7.1 u will see it in the display of the ipod
SOURCE: Ipod music shows up on the computer, but no songs when I disconnect it
No, be reassured, it is not dead. Be sure you have the latest version of itunes AND ipod software installed. That will most likely solve your problems. If you have moved things around in the ipod hard disk on your computer, restoring would have solved it. So just make sure you're up to date ;)
SOURCE: IPOD automatically disconnects
the settings in itunes need to be changed so that you can sync manually
SOURCE: ipod classic 80gb is frozen in Do Not Disconnect screen
hold down menu and start for 5 seconds and see if that starts it !1swampratt200!!AAEEE!!!
