How can I contact Motorola for support questions?
inside screen white - answer.gif"/uploads/images/answer.gif" alt="answer.gif" class="h_mi" />
Canada Customer Support Numbers
On Line and Telephone Order Inquires
1-800-461-4575
Broadband Technical Support
1-877-466-8646
Business/Government Two Way
1-866-948-5200
Cellular
1-800-461-4575
iDEN
1-800-453-0920
Messaging
1-800-461-4575
US Customer Support Numbers
Broadband
1-877-466-8646
US Cellular
1-800-331-6456
US Paging
1-800-548-9954
Consumer Two-Way
1-800-353-2729
Business/Government Two-Way
1-800-353-2729
iDEN (Nextel/Southern LINC/Telus)
1-800-453-0920
Consumer Modems
1-800-221-4380
Professional Two-Way Radios Spirit
1-800-448-6686
The cable that connects the screen to the phone is damaged, causing it to white screen. Other than sending it back to the manufacturer or having Nextel fix it, there's no fix other than for it to be swapped out.
buy a new phone and try real hard nt to drop it the a920 tends to pack up when dropped as it happened to my last a920 and even telecom went to repair it but it was going to cost more than the price of a replacement a920
try opening your phone and check if its flex connector is still in contact. if everything is fine then probably you have a problem in the flex itself...
if eveything is fine then worst you have a defective LCD..
I don't know why you can't answer your phone or why you banged it to get it to work but your inside screens connector may just have came loose as it sometimes happens with out you doing anything wrong. Just take it apart and check the wires on the solved problems I think there one that tells you how to do this.
kkk
I have the same problem with my Razr. It just unexpectedly turns white. The phone works fine, I just can't see anything because it is all white.
