Question about Maytag Atlantis MAV6000 Top Load Washer
Washer leaking water from bottom
All of the hose connections seem to be secure; however, during the spin cycle water comes out of the bottom of the machine Most of the water seems to drain through the the drain hose, but we are still getting puddles underneath the machine.
  • 16 more comments
  • Anonymous Feb 28, 2008
    Water leaks at the bottom of the washer and clothes aren't wrung fully?
  • Anonymous May 24, 2008
    same problem as above. water pooling underneath the unit
  • tedcsmith Jun 29, 2008
    same as above although mine is a Maytag quiet plus II. Have checked all the hose connections
  • jcmartin1 Jul 06, 2008
    I have recently purchased a second hand Atlantis top load washer. It leaks a small puddle of water when washing. Also, I notice when I moved it to clean the floor underneath, it leaves a light swirl of oily looking water on the floor. When looking underneath the machine I see evidence of along the bottom outer edges of the machine. It seems to work fine otherwise, any hints at repair. And if so, is it a do-it yourselfer, I am mechanically inclined, but do not have any special tools. Just the basic wrench, socket and screw driver sets, to name a few.
  • m_manwar Jul 18, 2008
    I have the Maytag LSE7806ACE. Mine was leaking water as well. I called my friend over who helped me replace the belts a few months ago (I burned them out from washing a king-sized comforter which was too large I guess). He took the front panel off the washer portion. The machine does everything except agitate. When the washer fills up and starts to wash (or rinse), the tub only spins which is causing the water to overflow out of that white plastic tub cover ( AP250092). And I can see water coming out of the liquid bleach dispenser as well. It is also not recognizing the Small/Medium/Large water levels. I tried to replace the water level switch but that didn't seem to make a difference. I'm broke and want to try and fix it myself. I have a great appliance parts store I can get any part from. Just need directions.
  • Anonymous Aug 23, 2008
    cannot access inside washer
  • dmaxwell321 Sep 02, 2008
    My washer overflows AFTER the water is disbursed into the machine. It seems to overflow while it is agitating and prior to draining and spinning. It overflows over the white lip and into the wall and floods the floor. My repair man has replaced a few parts - the first was a couple parts that were relating to the water not filling properly, which wasn't the case. He also replaced a brake - which didn't help. He thinks it has something to do with the Centrifugal Force when it spins when it shouldn't. The machine doesn't do it all the time, so it's hard to diagnose, as it never happens for the repair man.
  • lestersue Sep 17, 2008
    My washer leaking water from the bottom as it fills. I assume it's either the water pump or something else, but I'm not sure.
  • Anonymous Sep 21, 2008
    As I fill up my Maytag Atlantis washer, I see water underneath. All connections seem fine
  • jmanen Sep 24, 2008
    Water is coming out from under the washer and when I stopped it we could see at still leaking
  • chefdelydia Nov 11, 2008
    Like many of the others at this site, I have water leaking from under the Maytag Atlantis.  It leaks during the spin cycle, but I can also see it leaking from underneath if I fill the tub and stop the cycle.
  • Anonymous Mar 07, 2009
    I have a maytag sav365aww bought 5/8/04 water leaking from the bottom
    maytag washer leakingt the bottom help bought 2004
  • Anonymous Mar 10, 2009
    The water seems to be leaking from the bottom of the washer. A Maytag repairman came in and started the washer (without any clothes) in it and it did not leak. However, the next morning, there was a puddle by the washer. So, whenI put in clothes and start my wash, the leak comes immediately. When no clothes are in the washer and you start it (as a test), water does not leak at all. However, within the next day, there will be a puddle on the floor.
  • Anonymous May 03, 2009
    my washer is not leaking threw hose it is leaking somewhere threw the bottem of the washer. my washer is a GE energy star
  • lynneshipma Jan 04, 2010
    water leaking from bottom or washer
  • Rick Feb 19, 2013
    I found my leak to be the hose at the bottom of the fram (sitting ON the frame) where water exits the tub and goes to the pump. Turned out a small hole developped on the underside of the host due to vibrations over time (my guess) since no other parts are pressing against it. I had placed a few paper towels flat under the pump to catch the falling drips, but nothing came down, except the floor got a little wetter. Since only one hose was below the paper towels, when I lifted that hose a little water spilled out... Simplest things, whew, wish they were all like that...
  • Rick Feb 19, 2013
    had bottom hose under pump sitting on frame, developped a tiny hole (vibration?) and leaked... found it by place strategic paper towels under diff't parts of bottom washer guts while running... found no drops, but floor was getting wet... bottom hose touching frame was culprit.
  • 25 Answers
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check http://www.applianceaid.com/genew.html
Yours Truly,
Mr.Fix-it-guy
Posted on Aug 12, 2009
How do you take the agitator apart and remove it from the drum?
Posted on May 25, 2010
My washer pumped 1/3 of the water out onto the floor from underneath, and shut down. Where do I start?
Posted on Mar 14, 2010
  • 80 Answers
The problem is with the back flow preventer located at the top back right corner where the drain hose attaches to the back flow preventer. The back flow preventer has a vent on the top that will pressurize when the washer is in the spin cycle. The soft rubber washer fails and a small amount of water leakes out. I am looking for a handi man fix.
Posted on Aug 20, 2009
    Problem Solver:
  • 12 Answers
Check the pump (http://www.appliancepartspros.com/part_details.aspx?part_id=3447809), this is a very common problem with these models. Breakdown diagrams for your model: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46605 Hope this helps, APP tech http://www.AppliancePartsPros.com
Posted on Aug 08, 2006
Here is one possibility: I had the same problem, plus I had a rattling sound coming from underneath during spin cycle The hoses and tub seal looked fine. I the disconnected all the hoses and power and raised up the washer on blocks and poured water in the tub to get a better look. The water was dripping off one of water pumps at the bottom but I couldn't tell its source. I finally took off the water pump and found a crack on the pump housing. It was a very small crack and opposite the visible side so it just looked like it was coming out one of the hoses.. Also, two pennies fell out so I think they were the source of the rattling and also what caused the crack (the pennies being pushed around by the impeller knocking against the side). A new water pump is over $100, but I was able to fix the crack using 2 part epoxy repair rated for water. I used the two part "gooey" kind vs the "modeling" clay type expoxy figuring it would better seal a samall crack. I would not recommend using something like CA or crazy glue since they tend to melt the plastic and probably wouldn't be good for this particular type of patch.
Posted on Aug 20, 2012
  • jacksonrandy
    jacksonrandy Aug 20, 2012
Check the seal between the top plastic cap and the outer tub. There are 6-8 clips that secure the cap to the tub. My washer would leak water when full and start spinning. I found the seal split in two.
Posted on Mar 17, 2008
The pump housing is cracked perhaps
take the pump out and inspect it back and front unit look for cracks inside the vane housing
just takes a bit or bra wire or a coin or two to crack then then they leek on spin cycle or with sitting water look for any signs of rust if its there eventaully youll get electronics parts failure... add a bit of die to the machines full state add some die so wait till its full of standing water turn it off and look for the colour where it comes from
Posted on Oct 19, 2014
SOURCE:
My GE washer leaks water during spin cycle only, seemingly from bottom of valve(?) where water hoses hook up, hoses look to be in good shape, only a year or so old.
If it is leaking at where the drain hose comes out of the wash machine, make sure the plastic spider clamp is seated securely in the groove on the drain hose. If that's not it, then, yes, you'll need to open up your washer to gain access to the inside of it. I don't know which model GE wash machine you have, but most of the GE top loaders can be opened by following the instructions in this youtube video:
Oct 19, 2014 | Washing Machines
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Washer seems to be leaking during spin cycle.
If the water is gushing from the washer, check the small plastic air dome hose on the lower right hand side of the wash tub. Sometimes the hose can come loose and come off. This will cause the water to begin pouring out of the bottom of the the washer when it begins to fill. The following link has some other things you may consider as well:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak.
Another common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
May 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Sep 05, 2007 | Amana LWA40A
Maytag Atlantis MAV6000 Top Load Washer Logo
44,828 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
