Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
LG Dishwasher Model: LDF6810ST makes a loud grinding noise from the wash motor while running. After about 10 minutes into the cycle the dishwasher stops with a "E1" error code. I believe the wash motor is going, but I don't understand why the dishwasher is giving me an "E1" error code instead of an "LE" error code. Could I have multiple problems occuring or is this a common error code when the wash motor is going bad?
  • 3 more comments
  • sylvestre7 Oct 24, 2008
    I solved my own problem but thought I should share my experience. Just in case someone else runs into the same problem. It turns out there is nothing wrong with the wash motor. The grinding noise is actually water and air being mixed together because the water level was too low. The water level was low because water was being siphoned out of the tub while the machine was running. This would also explain why I would get a leak error code. The solution to the problem was an easy fix. I cut a coat hanger and made a s-hook to elevate the outlet hose. By elevating the outlet hose, water is not being siphoned out of the dishwasher tub.
  • Jeff Meyer May 11, 2010
    Neo,
    This really interesting and useful information from LG. Unfortunatly, the problems encountered by the original poster is on an LG Dishwasher [LG Dishwasher Model: LDF6810ST], not an LG clothes washer. I have not worked on an LG clothes washer before, it is interesting to learn both types of washers use (at least some of) the same error codes.
  • nenotech_neo May 11, 2010
    Here is text of very helpful email from LG
    When you receive the LE error code, unplug the machine for approximately 15 - 20
    minutes. This will reset the microprocessor.
    The LE error code can be an indication of several different issues.
    The most common cause is over-sudsing in the machine. Many times owners
    experiencing the LE error code are using regular detergent. It is recommended to
    use a high efficiency or low sudsing detergent. Many of the leading detergent
    manufacturers have a high-efficiency (HE) selection. The HE detergents are
    designed for lower suds levels and enhanced cleaning performance in
    front-loading washers.
    Overloading the wash with too much laundry may also cause the LE error code. A
    good rule is to load the washer until the clothes in the drum are no more than
    three-fourths of the way up the window of the door. This will allow them
    sufficient room for tumbling. The clothing having sufficient room to tumble is
    more important than either the weight or the number of items in the washer. It
    is the tumbling action that provides the washing effect.
    Lastly, a breakdown in the signal between the microprocessor and the motor may
    cause the error code. This can occur if there is a loose wire, dislodged ball
    sensor, or if the shipping bolts are removed prior to situating the washer. . In
    this case, a servicer would need to take a look at the unit. In this case, you
    will need a service center to look at your unit. For service assistance, please
    visit our website at us.lgservice.com Click on "Service Center". Enter your
    zipcode and product type. Click search.
    In the event that you cannot find a service center, please call 1-800-243-0000
    for assistance. There, an agent will be able to provide you with an Authorized
    LG Service Center in your area.
    Please have your model and serial number available along with your zip code when
    you call. If you have a customer service issue, please let the agent know and
    they will set up a customer service file for you. If your unit is under the
    factory warranty, your purchase receipt will validate the warranty.
    Business hours are 24 hours a day, 7 days a week.
    I have taken the liberty of providing some hints and additional information that
    may be helpful concerning your LG washer.
    If you must use a regular detergent, you will only need to use 1/2-1/3 the
    amount you would normally use in a conventional top-loading machine. However,
    the HE and the conventional detergents are different formulae, and your machine
    will not perform as efficiently or effectively. Using half the required amount
    of regular detergent will
    give half the cleaning performance. As the new LG washers accept a larger than
    usual load, the cleaning performance could be further reduced. In addition to
    the reduced cleaning, there will be oversudsing. The excess suds will cause the
    washer to stop and rid itself of the suds before continuing its cycle. Getting
    rid of the detergent will further reduce cleaning performance.
    Using too much detergent can cause a build-up on the outer drum over time, which
    can result in mold and even mildew growth in your washer. Should this occur, do
    a load of whites on the SANITARY cycle. Use the extra rinse and stain options.
    Use NO detergent and use a liquid bleach. This will remove the build-up and any
    odors accompanying it. This procedure may need to be repeated a couple of times
    depending on the degree of build-up.
    The washing time may vary by the amount of laundry, water pressure, water
    temperature, and other using conditions.
    The 'SenseClean Washing System' has a built-in turbidity sensor that measures
    the detergent/suds residue in the water during the rinse and then makes an
    adjustment of time and water usage based on the detected residue level.
    The machine will detect an imbalance and attempt to correct it. If the imbalance
    is detected or if the suds removing program operates, the wash time will be
    increased.
    A built-in water heater in the washer assures that incoming water is the correct
    temperature to optimize cleaning performance. Most laundry detergents must be
    activated at certain temperatures to work correctly. We use thermisters
    (electronic thermostats that have a high degree of accuracy) to detect incoming
    water temperatures. Our 1000-watt heater adjusts the incoming water to ensure
    superior thermal action performance.
    You won't see a "visible" water level in the window of the unit. The water is
    pooled in the inner drum. RollerJets are built into the baffles of the washer.
    The holes in the baffle collect water and re-circulate it during the wash. This
    increases the mechanical action to achieve best cleaning performance. The
    rollers gently move fabrics
    along in the wash cycle.
    This action aids in reducing the amount of water required for thorough
    cleansing. In contrast with a top-loading machine, which always fills the
    machine to a precise measured level of water, depending on the size of load you
    select (small, medium, large), the LG machine will "sense" the size of the load
    and only recirculate a minimal amount of water, thus making it very energy
    efficient, efficient in the use of detergents, and extremely efficient in its
    water usage.
    Forced Water Circulation in the washer pumps water during the wash. It
    recirculates it back up and over the laundry to further increase mechanical
    action and cleaning performance.
    With front loading washers, the door seals so very tightly unlike a conventional
    machine, that it is recommended to dry the seal when you are done with your
    laundry for the day to prevent an atmosphere where mold and mildew can grow.
    To get the best results, sort clothes into loads that can be washed with the
    same wash cycle. Different fabrics need to be washed in different ways. Always
    sort dark colors from pale colors and whites. Wash separately as dye and lint
    transfer can occur causing discoloration of white clothing. If possible, do not
    wash heavily soiled items with lightly soiled ones.
    Combine large and small items in a load. Load large items first. Large items
    should not be more than half the total wash load. Do not wash single items. This
    may cause an out-of-balance load. Add one or two similar items.
    Hope This help
    Good Luck!!!
    neo
  • frank mohr Jan 18, 2014
    http://lgdishwasher.yolasite.com/ SEE MINE. NOISY OVER AND OVER
  • Anonymous Mar 23, 2014
    Running. Cannot be shut off. Error code e1
Ive got an LG LD1204w1 model dishwasher, the grinding sound started about a week before the E1 error code and incessant dinging began. I found FixYa the best site for LG solutions, the wiring had fused to the lining on the door as suggested, so a bit of electrical tape has done the trick as far as the E1 error and dinging is concerned (thankfully no broken wires)
However I still have the grinding sound during the wash cycle. Drainage and fill hoses are to specifications stated by LG, there is no wear on inspection, the unit isnt losing water during wash so the air/water issue I dont think is relevant to my situation. Is there anything else that could possibly be causing the awful noise its making? The noise seems to be coming from the bottom/underside of the dishwasher.
Posted on Jul 23, 2010
  • 423 Answers
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Posted on Mar 30, 2009
SOURCE:
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
WHY DISHWASHER MAKES A WHINNING NOISE
If the dishwasher is making a loud whining noise, the drain pump or motor bearings are defective, the drain impeller or wash impeller might have worn out. All these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Jul 14, 2014 | LG LDF6810ST Stainless Steel Built-in...
Ld14aw3 error code 0e lg dishwasher
LD 14AW3 Service Manual pdf
Mike - Here is the service manual.
Use - ld14aw3
Apr 07, 2014 | Dishwashers
LG LDF6810ST whine noise
-After paying an LG serviceman for a home visit, I told to refer to the manual-and there in small print-USE ONLY POWDER CLEANER. Gel and liquids make too much bubbles(thus air) in the hose producing the noise. It will take several washes-but the noise will go away!
Feb 24, 2013 | LG LDF6810ST Stainless Steel Built-in...
My lgis making a horrible noise and is now shoeing an e1 code dishwasher
The LG does suffer from "poor quality" motor that causes this type of noise. The main motor and pump assembly is common to give this type of problem. The pump seal leaks a small amount of water that gets onto the front bearing and causes a "grinding = humming" noise. This can be easly replaced once you have the bottom off and dishwasher on its door. The motoe has 1 screw in the back holding the motor to the bottom and two rubber seals for the water pump in/out into the washer. Just pull and move motor and pump assmbly and it comes free. Replace with a new motor and pump assembly...
Nov 18, 2011 | LG LDF6810ST Stainless Steel Built-in...
My dishwasher LDF6810ST is showing an error code E1- I tried the checks that fixya gave me - there are no leaks. I called customer service and he said I would need a repair man. Please refund my money
Hi ardyhansen,
Please check my tip on a solution for this precise error, hope it helps:
CLICK HERE -> L.G DISHWASHER E1 ERROR
Kind Regards :-)
* If you found this solution helpful, please rate it
Jul 09, 2011 | LG LDF6810ST Stainless Steel Built-in...
My 1yr old dishwasher is makes a whistle noise
Hi jgonsalves,
Please check my following tip for the full solution to your problem.
Click here -> L.G E1 Error / Whistling Sound
Kind Regards :-)
* If you found this solution helpful, please rate it.
Jul 06, 2011 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher sounds like it is straining LG LD-2040WH
E1 leakage error
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
Replace the Impeller of the Washing Pump.
Aug 30, 2009 | LG Dishwashers
LG dishwasher is making loud grinding sounds
debris in pump. unplug and disassemble pump. clean out and reassemble
Aug 26, 2009 | LG LDF6920ST Stainless Steel 24 in....
What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Feb 15, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
5,551 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
