D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
A
Anonymous Posted on Feb 05, 2012
Does D-link DI-624 have a PIN number?
Setting up a Netgear Booster and it is asking for a PIN number
5 Related Answers
Anonymous
  • 239 Answers
  • Posted on Dec 24, 2007
SOURCE: D-Link DI-624 wireless router is not working after firmware upgrade try
Try to unplug the router and hold in reset button for 30 seconds see if that works, you probably did that already, But if you can get your computer to respond you should be able to open software Bios. and do your firmware update from there. If not I believe a hard reset is with the router plugged in and holding reset button for 30 seconds, I don't know I sure hope that resets it for you. Thanks take care
Anonymous
  • 89 Answers
  • Posted on Mar 21, 2008
SOURCE: D-link DI-624
Hello, 192.168.0.1 is usually the default address. If the router is connect to the PC or Laptop with a straight through ethernet cable, browser should connect. The only reason is the default has been changed. The easiest thing would be to set the router back to default. Push reset on back of router for 5-10 seconds. Then try to access with default address. Username is "admin" leave password blank. Hope this helps.
MysteryFCM
Steven Burn
  • 187 Answers
  • Posted on May 26, 2008
SOURCE: D-Link AirPlus Xtreme G DI-624 - Setting Wireless Key
You don't need any software, no. All you need to do is login to the router (usually 192.168.2.1 or 192.168.1.1 for D-link) and configure the wireless security (including the key)).
Anonymous
  • 63 Answers
  • Posted on Dec 25, 2008
SOURCE: where can I get a free d-link DI-624 installer online?
There are multiple revisions of the DI-624, each with version specific drivers, firmware, installation guides, and other resources. Please use the descriptions below to identify your revision.
The links will take you to the drivers and install guides.
Note: The revision is located on the label on the bottom of the device next to H/W
The DI-624 Rev. A has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624v.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624
The DI-624 Rev. B has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revBv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI%2D624%5FrevB
The DI-624 Rev. C has only 1 antenna.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revCv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624_revC
Anonymous
  • 404 Answers
  • Posted on Aug 14, 2009
SOURCE: I need the cd-rom for wireless router d-link DI-624
Hi! u dont need to download the cd for the router in order to setup ur wireless dlink router.. u could just pull up a browser and type in at the url:192.168.0.1 and it will ask the username and password, by the default the username is admin and for the pass, just leave it blank.. then it will pop up the setup page of the router, if u cant access the setup page bcoz username and pass is denied, press the reset button on the bac of the router for 10secs while power is on. it will set to factory defaul and by that time u can access the setup page.. i hope this will help..
Need the 6 number pin for d link wireless dl 624
If you can reset the router back to factory settings(see below)
http://www.ehow.com/how_8417689_reset-dlink-di624-router.html
then you should be able to enter the default pin number inside the user's manual. Other than that, I'm not sure how you could retrieve it once it has been already set up.
After i enter the the number is asking for pass word I enter the admin but keep asking for pass word
Check the manual:
http://files.dlink.com.au/Products/DI-624/Manuals/DI-624_Manual.pdf
If you login as admin, password is (blank).
...but, you might have changed it.
So just press the rest button (>5 sec) and this restores the system back so you will be able to use admin password.
How do I do this "Type the unique PIN into the
Hi rhienjen,
Each router has its own unique PIN. The PIN will be asked only once for setting up your router.
You can find the unique PIN behind the router written on a sticker which states the model number, serial number and the pin number.
If this information was helpful for you, please rate it.
Thank you for using fixya,
Arun Zac
1helpful
Lost software to d-link di-624. how do i get another?
contact d-link and ask them to send you a copy or you may be able to down load software from there web site. good luck
2answers
1helpful
Where can I get a free d-link DI-624 installer online?
DI-624
use the wizard...
what are you having problems with
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
