Disassemble, open case
You need to gently prise off the front speaker grill. You could use a blunt pen knife to do this. After you remove the grill You will see 4 additional screws at roughly each corner of the front panel. Unscrew them and then you can use the pen knife once more to prise apart the speaker housing. Prise the housing apart from the top because two base pads hold both halves together at the bottom. I hope this helps! :)
How can I get speaker woofer spares
