I start the bottom for self cleaning and after showing that the door is locked appear in the screen F9 .
Door is locked and is not opening I disconnected from the power supply but still showing the same error and the door is locked how I can fix the problem
thank you in advance
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question)(*&^%
