Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega trintron wont turn on
How could i fix the problem with my tv. it flashes 7 times then turns back off
    Genius:
  • Sony Master
  • 1,691 Answers
Most likely there is a failure in the power supply or in the scan amp sections. This will require factory level troubleshooting to determine where the faults are.
This type of service may be on the expensive side.
Jerry G.
Posted on Nov 25, 2008
SOURCE:
My tv wont turn on ,It seem it is going to turn on and close itself
Searching for tv turns off but will turn right back?
  • Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Nov 26, 2012 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony Wega trinitron TV wont turn on..Keeps shutting off and standby flashes 7 times
Thank you for your question.
Fortunately this is a common symptom and there is a fix for it.
There are two power supply IC's and a capacitor that need to be change. In particular IC6501, IC8002, part number, Mcz3001db, and C6556, 33uF @ 160V.
Jul 15, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV wont turn on, sandby light flashes 7 times.
Any malfunction associated with a flashing stand-by light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
I have a 36" Sony FD Trintron won't turn on and no sound
Have you tried unplugging it from the wall for a couple of minutes, this may reset it.
Jul 26, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
IC/high power transister(s) and/or other componentshas gone bad gone bad - usually from a power surge. These will have to be replaced. A technician should check these out for you.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have the sony trintron wega 32 hs 500
Seven blinks indicates a high voltage shutdown which has exceeded 33,000 volts and immediately sends the unit into a safety shutdown. In this case you would need to check the power supply regulation circuit and horizontal circuit for the failure. It could be as simple as the horizontal output transistor having failed to something more complex or expensive. Need to have it diagnosed for that to find out.
Bill
Apr 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
WILL NOT TURN ON
You may have to replace D6116 and D 6301 on the "G" board.
Jan 16, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
205 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
