Got to see if it's a fuel problem or electrical/ignition problem. Spray a little starting fluid into the carb or air cleaner as close to the carb opening as possible. If the scoot tries to start even a little bit then you have a fuel problem. If nothing happens with the starting fluid start checking for electrical things. Shut off switch, key switch, broken or frayed wires, bad battery connections and on and on. Good luck
