SOURCE: Hp sp 323091 001 motherboard manual
The information that you provided is not specific to the motherboard that you have. I'm assuming that your motherboard was manufactured by Intel. You will have more luck if you can find out what company manufactured the board and also the correct model number or name of the board.
However, most motherboard have a series of pins somewhere very close to the edge of the board and, this would be the edge that sits closest to the front panel. Most motherboards that I work with have a series of pins near the edges labeled "Panel". These would be the pins that you will use to connect the power switch, power LED light, HDD LED, etc.
Usually, there are even smaller letters that, if you look closely, label each set of pins for the appropriate connectors. Take a very close look along the edges of your board to see if you can locate these pins or the word "Panel" which would be written just beneath a group of pins on the board. Some boards even go as far as to label the pins for which connector they belong (for example, there will be maybe 2 rows of pins and some connectors will only use one pin, on one row while others may use 2 pins).
Hope this helps (that is if you still have the board or this problem)...
SOURCE: sound card problem
If you have the HP D330 Desktop, you can download the audio driver from HP's Download Page (Windows XP).
If you do not have this model, please post the HP model number and I will find the drivers for you!
