Archos 605 WiFi Digital Media Player Logo
Posted on Oct 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Archos 605 wifi recovery code 107
I switch on my device, and asks me would you like to recover it? recovery(code107)
no
repair
format disk
what can i do????
  • 5 more comments
  • serinea652 Oct 26, 2008
    When turning on Archos 605 Wifi. It states system is damaged Recovery code 107. Would you like to recover? When I enter Repair or format disk it just restarts with the same problem. I was using it fine until this happened. Is ther a problem with my hard drive? Any help would be greatly appreciated.
  • Anonymous Dec 02, 2008
    i have the same problem mate.....
  • robte Dec 11, 2008
    Yes, mine just went down with the same error and it is non recoverable. I phoned Archos (France), and they asked me all the usual questions...will it reset via the reset pinhole (no).......can you repair or refromat it via the white screen (no)....does the computer recognise it in Windows explorer (no)......and the upshot is what we already know 'system is damaged' i shall email you with an address where you can send it for repair. I made the comment that this is not the first time the unit had crashed and to recover full functions i have reformatted it about 4-5 times; I think they have a problem with this, the chap said that after they have had a chance to repair it this will not occur again, but frankly the device has been very tempremental especially when transferring larger video files to it which it should be able to handle as they are under the 2 GB limit. Robbo
  • macdre Dec 23, 2008
    My 605 states''Would you like to recover your system?Recovery code104.Ive tried formating,but that doesnt work.ive tried the repairing only to get the same results.what can i do besides throwing the thing away?
  • Anonymous Aug 31, 2012
    Dear Volkan user, I did not try your HD problem, yet. But I want to ask you something; Will it be a solution for the other error codes, like 104, 207 and 103? What do you think about this? I have an issue especially these other errors; it's link is :http://www.fixya.com/support/t14171359-2... . Thank you in advance for your comments.
    I meant "HD Solution", sorry.
  • Vijay Hudson Sep 28, 2013
    I'm also facing the Same Problem..
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1521
Points
Carbon Adsorption Solvent Recovery Systems
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Feb 01, 2010
Anonymous
Expert
Level 2:
Answers
61
Questions
Helped
58133
Points
121
Do not pick any just turn it off. I have tried this many times and believe me it worked. You need to open the back cover and unhook the HDD turn the device on after Hdd taken out and turn it back off. This will trick the system and plug HDD back in turn on the archos before closing the cover. If it works you got yur unit back if it does not then my suggetion is use another HDD to trick the system make sure to mark the original HDD is marked swap the HDD and turn onn and off. Put the original back in turn it back on http://www.youtube.com/watch?v=SzhLk16jbvw
  • Anonymous Feb 01, 2010
    Guys please leave feedback for the fix i have posted if anybody tried.
Anonymous
Level 1:
New Friend:
  • Posted on Jan 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1521
Points
Recovery 107 sistem is damaged.would you like to recovery it?
no
repair
format disk
3helpful
Recovery (code 104)
From Archos' support website FAQ:
When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted.
With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk".
Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=us&lang=en
When i turn it on it goes to a white screen with a blue line across on the very top it says recovery code 108 the next line says "would you like to recover your system?" then it gives me three...
when i turn it on it goes to a white screen with a blue line across on the very top it says recovery code 108 the next line says "would you like to recover your system?" then it gives me three options no, repair disk, and format disk. I dont know what to do cam body help me?
Archos 605 wifi white screen on start up!
I cant help directly but I can suggest you get on-line to http://forum.archosfans.com they have some pretty clever guys there that contribute
3helpful
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Wont start recovery 102??
Remove your memory card and restart your archos, when it asks if you want to repair blahblah... just keep pressing the cross till it loads as normal with the sd card 'out', this should work, to stop it happening in the future format your memory card 'sd' with your archos once it has started. Hope that helps!
Sky DD
3helpful
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
2helpful
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
5helpful
3answers
ARCHOS 605 WIFI FIRMWARE DISABLED
hitesh_rao - the reset button is at the bottom by the USB and docking ports. Tiny hole, need a pin or paper clip. Once pressed, just switch it back on.
This may be a stupid question, but when trying to configure the TV IR controller function and entering the relevant codes for my TV's, it asks 'did the TV switch off = Yes/No?'
None of my TV's switch off and then I cannot go any further with the config. Is this right? I have logged this with Archos FOUR times now, and they just respond with 'the controller does not control your TV'. I am fully aware that it is not a TV controller, but then why does it want to switch off my TV during the config? I just want them to answer that question.
Somebody please help!
25helpful
5answers
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
