Electric 24 volt Scooter
After getting a new set of batteries, now when I turn on the key the scooter's motor engages and takes off. I have the wiring diagram and everything looks right, what could be the problem?
SOURCE: Need service manual or electrical wiring diagram.
one ofthe best ways to work it out is the find the motor controller, normally it's a black box located under the seat,
Now remember you have two wires from the batteries B+, B-, two wires to the motor, M+, M- and some smaller wires on maybe a ten connector block that leads to the tiller where the throttle on the handlebars is located.
Hope that helps
Regards
GeWiz.
SOURCE: Need a wiring diagram for Pride Rally Electric Scooter
I can tell you how i fixed it for $19.95
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
SOURCE: electric mobility scooter says charge is full but won't run
Hi. Most chargers should be connected to the scooter first before plugging into the wall socket. The charger senses the battery voltage to regulate itself. Your other answer suggested the circuit breaker, and this might be correct. Sone times the circuit breaker blowing can mean there is other faults such as a faulty motor. Many mobility scooters have plugs and sockets on the battery leads, and most are too light to carry the high currents. I have removed these from many machines and connected the leads straight to the batteries.
The third pin in the charger plug is to disable the controller in the scooter while the charger is connected.Good luck. Neil.
SOURCE: wiring diagram for sc234ala mobility scooter
Hi. Do you need a basic wiring diagramme for the lights, motors etc. or do you need one for the controller? What faults do you have?
Fisher and Paykel sold their mobility scooter business to Plega Healthcare in Australia. Plega now no longer suport the mobility scooters.
We have some parts left in stock, and were an authorised service agent for these machines.
No one was ever supplied with a circuit diagramme for the controllers.
We do have all the service manuals here and have a full set of the fault codes.
You can email us at [email protected]
Good luck. Neil.
