Question about Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX)
Iphone with Motorola 3347 router and H.264 DVR
Ports 9000, 1024 and 15960 (iphone) opened in the router DVR set up the same accessible from the same network PC. I still can't get passtrough the router to DVR. What else I need to set up on the router and which parameters to enter in NAT, DDNS. ATT DSL PPP small business service. Thank you
SOURCE:
pastorm
  • 98 Answers
SOURCE: netopia dmz
Take a look here: http://www.netopia.com/support/hardware/technotes/CQG_027.html
Posted on Aug 02, 2007
cnavarro
  • 2460 Answers
SOURCE: Programming Netopia 3347 wireless router
You mean what program? Telnet. Here's the quick setup. If it's already been installed and password protected, you'll need to grab the installation guide somewhere else.
http://www.netopia.com/support/hardware/manuals/3347W-ENT_qsg.pdf
Carl
Posted on Aug 29, 2008
SOURCE: Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
Posted on May 07, 2009
  • 3 Answers
SOURCE: Qwest DSL / Issues with Motorola 3347
The modem overheats due to lack of ventilation. I fixed mine first with Ice packs then a small twelve volt fan and some inexpensive heat sinks glued to the top of the two processor chips.
You need to cool the modem down!
Posted on Aug 17, 2009
  • 3 Answers
SOURCE: Getting PS3 NAT type 2 with Netopia router!
u should have dmz on router. but if not u can try your modem. that was my issue. i still use router for connection and stuff but i enables ip/dmz to pass through on my modem and it changed to type 2 more info email me at joshuaboo@aol.com on add me i believe my ps3 thing is ADV_WARfighter
Posted on Sep 24, 2009
Pls help me step by step how to online viewing from my cctv
You need to provide us with more info. Your dvr broadcasts on an iPhone address with a port number. Both of these are needed. Then the bbrand of router you have is also needed
Nov 24, 2014 | ECHO1USA 4ch H.264 Standalone Dvr 204e...
Best Picture Quality - JPEG2000 DVR - Netopia 3347
Just reinstall agin the firmware or update it & take a soft reset of the unit
Mar 07, 2008 | Netopia (3347NWG-VGX) Wireless Router...
I cannot access my internet viewer
More details are required.
The Samsung 'SmartViewer' program starts up on a computer. You can access it whether you have a recorder or not.
The Samsung 4 channel DVR has a menu to set IP address & ports to use and a netjack to connect to internet. You can access the DVR from any computer connected to the same router as the DVR by inserting the same correct info into 'SmartViewer' as in the the DVR.
Once you open the required ports in your router, port forward the router to the DVR, any incoming requests from the internet to view should connect and with the correct password you can view your security cams.
With minor adjustments..that's it.
What didn't you do?
Dec 25, 2012 | Samsung 4 Channel Dvr
I have a H.264 DVR with system V2.00.R05. What app or system can I use to view on a iPhone 4S?
IP CAM VIEW found in the Itunes Market: http://itunes.apple.com/us/app/ip-cam-view/id471794610?mt=8# should work as long as you have the network settings properly configured in both your DVR and Home Network. I recommend setting a Static IP for the DVR on your Home Router. After you have assigned the IP goto the network settings on your DVR and input the IP Address you assigned, the SubnetMask of your Home Router(usually 255.255.255.0 or 255.255.252.0), and the Gateway of yourHome Router.(i.e. 192.168.0.1/192.168.1.1/192.168.1.254). While you are on your Network screen I recommend changing your default TCP Port andHTTP Port to something that is not commonly allocated. As with most Routers you must Create a pinhole in the firewall to allow the outside traffic in. Select your DVR's IP on your Router and Create Definitions for both Ports that you set on your DVR's Network Menu. If your DVR and Router didn't reboot after saving these changes reboot.On the phone ap I found the following two cameras to work with the H.264 DVR System V2.00.R05:
  • Make: Unknown Brand Model: DVR-9008HV
  • Make:A.V.Sistemi Model:A.V.Sistemi 61xx DVR
For the Host/IP field, You use your Home Routers Internet IP. TCP port is the number you set on the network menu of your DVR. Ch.# is the Channel Cam (1-8, and 9 being a single feed of all 8 channels)user names and passwords are case sensitive.
I hope this helps
Jul 07, 2012 | Apple iPhone 3G
How to find password for motorola 3347 dsl
If you take a paper clip, or something sharp, and insert it into the little reset hole in the back of the router, and hold for 15 seconds or so, that'll reset the router. Wait for all the lights to stop flashing and remain on, then try to connect to the internet.
Or you could type www.routerlogin.com into your internet address bar and it'll ask you for the username and password, the defaults are admin and password..
Then, from the menu, find Restore Factory Settings, and Apply it. Wait for the process to complete 100%, this sometimes takes up to 30 seconds after it says it is complete, and then exit the browser. Now open the browser again and you should see your homepage.
Oct 18, 2011 | Arris 3347 DSL 4-Port Wireless Modem -...
I have AT&T DSL service with a Motorola 3347 modem. The wireless function was working just fine when I set it up yesterday, but now it's decided that I only get limited access (i.e. nothing) on the...
power down the modem . Check ADSL filters match the ADSL service eg ADSL 2 service has ADSL 2 filters.
Power on Modem wait 5 minutes for it to resync with DSL and see if internet is back up.
Aug 02, 2017 | Arris 3347 DSL 4-Port Wireless Modem -...
I have a 3347 motorola modem and I have two
If you have a Private IP address from the Modem like 192.168.1.65. 10.10.10.254, 192.168.2.45, etc.... the the NAT will be an issue, for games like Dawn of Death 2 which need more Bandwidth when joining the Game Server the WAN IP address which is from your Modem need to Public like 65.24.85.148, 72.54.36.94, etc... if you have a WAN IP address then check the Firmware of your router and if possible get the specific port number from the Game Administrator and open it on your router so that you wont have NAT issues.
Mar 23, 2010 | Netopia 3347W-KIT ADSL Wireless Gateway,...
Netopia dmz
Aug 01, 2007 | Netopia (3347NWG-VGX) Wireless Router...
Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX) Logo
173 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
