I refilled my ink but would like to reset ink levels. I removed the CMOS battery for about 5 minutes but it did not reset the ink levels. I reset the entire printer by pressing (*# together and 123 and right arrow) but still no luck. Anyone can help here obviously the printer is storing the ink cartridge ink information.
SOURCE: My HP Photo smart Premium All in one printer C309a
If you have the Win7 full-feature driver installed, try installing the Software Patch. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77751-1&lc=en&dlc=en&cc=us&os=4063&product=3737195
If you managed to get the minimal driver set or the OS driver, uninstall that and disconnect the printer from the computer and install the full featured software
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=4063&lc=en&dlc=en&cc=us&product=3737195
If you can't download the full file and get an installation error from an incomplete file due to connection errors, the link to the full software above also has a link to order a new CD with the drivers.
Sometimes the scan error (when the printer itself works) indicates that the HP monitor isn't running (due to incomplete install or turning off the program (not letting it run at boot, for example). The other cause is a poor connection since scanners need bi-directional communication with the computer. Try a new data cable, plugging into a different port. If you have a print server or USB hub, try a direct connection.
I hope this helps.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
