E:91:01 is an error code that indicates that flash circuit board is not working and need to be replaced to solve the problem. Let me know if you need part number of flash circuit board.
The error message is saying that the high voltage capacitor that creates the flash is not charging. There is probably a burned connection inside the camera or the bulb is bad - do not attempt to fix unless you're aware of getting a good jolt of electricity if you touch the wrong thing. Take it in to a repair shop.
Hi, The error shows that(Abnormality when flash is being charged.) the problem in in FLASH UNIT, it needs replacement, the part number is given below according to the model number you mention DSC-W55 Part No. 1-479-663-31 Description (FLASH UNIT). Thanks for using ifxya.
Hi! It's a flash error. Could be flash fuse or flash board. If you have a multimeter and you're ready to open it, contact me at [email protected] or contact your local Sony service center. I work in a Sony service center.
Hi!
E:91 is a flash error. The flash fuse on the main board or the flash board is bad. Contact your local Sony service center, but
if they ask too much, you can contact me at [email protected]
and I will give you a good price.
I work in Sony service center.
Hi, Its an error of flash unit(E:91:01 denots flash unit problem) which get started malfunctioning. Therefore you have to replace the FLASH UNIT ASSY. For changing of flash unit assy. You can contact any sony service centre nearby to you. For your convenience please visit: www.sony.net or www.sonyworld.com Here you can find contact info of nearest service centres. Thanks for using FIXYA.
It's a flash error, something has malfunctioned with your flash and the system board will continue to give this error until reset by service technician
