Where is the lamp located on a 50v500 hitachi television
SOURCE: HITACHI ULTRAVISION 50v500
Hello
This is usually not a repair a layman is able to do
as the ammount of plugs and wiring that go with it.
also the tubes have to be set up after installation .
The actual problem may be the red driver transistor or a cold solder joint.
I recommend a tec. to repair it.
Thanks Guy9
SOURCE: We have a 50V500 Hitachi Ultravision TV, temp and
Howdy,
You need to replace the lamp; UX21511 about $100.00 for a replacement. It is very easy to replace.
Good Luck, big IRISH.
SOURCE: How to replace the lamp or lamp assembly in a
Do you have the hitachi user manul for your TV.
If you have it The page number 69-73 gives you more details step by step to replace the lamp.
If you do not have a manual please let us know.
Regards,
BEADHZ
SOURCE: Hi I have a Hitachi
Go to Hitachi.com and put in the model# of your tv. The manufactruer has made it to where you the comsumer can change the lamp yourself. Use a vacume to clean out any dust. Hope this helps.
