> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
THANK YOU!!! I haven't been able to hear **** for like a year and just by pressing that volume equalizer button, the volume output increased by like 500%. THANK YOU! I was contemplating getting a set of speakers to hook up.
This solution really worked for me on my Acer Extensa 5210. Have good hearing, but ITV Player
The sound of each application played in the system can be amplified up to 500%. Letasoft Sound Booster can increase the volume of programs such as web browsers, online communication software (Skype, MSN, Live), any media player or game. Simply put, with Letasoft Sound Booster, the volume of virtually any program that can play any sound on the PC can be increased to a comfortable level. You can control the current volume with the pop-up slider in the taskbar. Alternatively, you can use system-wide hotkeys to increase or decrease, and use them when you need to adjust the volume. Letasoft Sound Booster constantly monitors the current gain level and prevents samples from becoming saturated, thereby avoiding larger sound distortions.https://keygensoft.com/letasoft-sound-bo...
Also check the audio mixer( right click the speaker icon on task bar) and see the level for wave etc. if its set too low you always hear low volume.
I had the same problem (Windows XP). Here's what worked for me:
Control Panel (using Category View) > Sounds, Speech and Audio Devices > Sounds and Audio Devices > Click the "Volume" tab along the top (if not already there) > near the bottom in the "Speaker Settings" section, click "Speaker Volume" > "Restore Defaults"
G
Right click on the audio settings, go into the advanced speaker options, and select stereo laptop speakers. It automatically makes it louder.
I had the same problem. Do the above, but also go to Sony laptop setup. There is a simple bass/treble equalizer. Put both levels to maximum and you should have an acceptable volume level. If you no longer have the setup utility, you can download it from the Sony website.
Also you may want to try Letasoft Sound Booster. It allows to boost volume even if it is already at the maximum.
This is a very common problem with Windows 7 OS, it doesn't matter which laptop you are using..Get the help below..
http://microsoft-support-squad.blogspot.com/2012/06/fix-windows-7-low-volume-problem.html
Try setting the volume of your default audio player to max even if you are not using it.
Check to see what other video players you have on your computer. I've noticed that real player, even if closed, affects the computer volume. Open real player and set volume to max, which should fix the problem. NB. volume stays loud even after you close real player
Try downloading vlc media player from the net and using that to play your files
diz
Try checking the program you are having problem with perhaps it has volume cointrol of it's own
old PC, laptops and runs XP no doubt.
all laptops have weak sound, all do
use external powered speakers. bingo LOUD!
but if they had said, it was loud before but not now, then here is that answer.
clearly:
first off the OP never gave a clue as to what media they were using, DVD can have weak sound, (using wrong audio choices in the media players does that)
nor if internet sounds, (name a URL)
nor if playing MP3 CDs. or CD_CA store bought music, not one clue stating what you are doing.
OR?
lets say even windows SOUNDs are weak.
NOw that is clear as bell.
The first cure and alway first on ANY PC
is to get the correct XP drivers for sound/audio from HP.com (or MS,microsoft)
no other driver is better, matched.
loaded then use Control panel sounds to set the sound VOLUME as you want.
just 2 steps, 1":load the correct driver.
then 2: adjust it as you wish.
but XP is virus magnet and if the OS is corrupted as Most XP PCs are all hope is gone.
SOURCE: low media player volume
Hi there... You can reinstall the sound. First uninstall the driver then reboot then install it...
SOURCE: volume at 100% and sound too low to watch dvd
Just cross check the volume settings in volume controls. All the sliders should be at max level specially Volume Control and CD Player.
If it is fine then there is some thing wrong with the media you are trying to watch or can be problem with audio driver.
SOURCE: poor volume
Need to do Powerdrain. Then do a BIOS update. Them reinstall the sound drive and restart the Laptop
low
mee too... The volume is very very low even in max vol.
brilliant genius
thankyou
I have lost my volume completely! (or my hearing)
i had a problem with volume, when i formated my loptap everything is erase including the volume i can hear from my laptop
my laptop ACER Extensa 5620Z has low volume...
my sound is too low to watch dvds but all volume controls are up to the max.
Sound is very low even at max volume
DELL COMPUTER, Volume VERY LOW
was fine 3 days ago
