Garden Logo
Posted on Feb 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace fule line on ryobi wipper snipper I - Ryobi Garden
Anonymous
Level 2:
Sergeant:
  • Expert 316 Answers
  • Posted on Feb 19, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
316
Questions
0
Helped
132100
Points
531
Hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D.3/32 and O.D.3/16 are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly,this is for most fuel line trimmers,any comments welcome,thank you. ``
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
342
Points
1 Related Answer
rwvanlue
Roland W VanLue
  • 486 Answers
  • Posted on Nov 12, 2009
SOURCE: Hi, hope you can help. My Ryobi Scorpion wipper
Rob, How have you determined that there is no spark? Have you used a type of spark tester? What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
If you do not have a spark tester, remove the plug, and with it connected to the wire, find a portion of metal around the cylinder that you can ground it on, and then pull the rope. If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
Worth it? If you can do the work yourself, I believe you will be OK. Depending on your parts availability, and the amount of time it takes.
Get back with me on how this issue works out.
thanks, rwvanlue
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
1helpful
Manual Ryobi model RCT3160E wipper snipper
makers website. and download
Oct 21, 2014 • Garden
I want to know how to install a blade on my husqvarna wipper snipper 128ldx trimmer
The only blade acceptable on this trimmer is a grass blade. Part number is 578 44 40-01
1helpful
3answers
Ryobi Weed Wasp starts but cuts out after 2 to 3 seconds.
Sounds like it is running on the prime. Check the fuel filter in the tank and if it looks clogged or dark, replace it. If that is not it, now is the time to consider a carburetor clean and rebuild, with a replacement of fuel lines and primer bulb. Today's ethenol in gas is murder on small engine soft components.
Ryobi petrol weed eater
SOUNDS LIKE YOU MAY NEED TO REPLACE THE FULE LINES THAY DO GET BAD OVER TIME
1helpful
Hi, hope you can help. My Ryobi Scorpion wipper snipper has no electricity going to the spark plug. Is their a way to fix this either with or without a replacement part or is it not worth it? Thanks, Rob
thanks, rwvanlue
1helpful
How do i replace a shaft for ryobi whipper snipper
I never heard it called a whipper snipper before but I am on this side of the ocean. you should be able to go to www.ryobiuk.com. Put in your model number and you should find a parts list for it.
HTH
Good Day. mate
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
