Sony BDVE770W Theater System Logo
Posted on Feb 02, 2012
Download incomplete on my BDVE770W? is there a hard reset?
I Have a BDVE770W and I went to do an update and it went 1-9 fine then after that it stopped and now says "download incomplete" I've unplugged for an hour plugged it back in and nothing! I then held the power on button and the stop button down together and nothing! its froze up i think. I can see the main home page on my tv but can't navigate through the menus. the main unit window just says "download incomplete" please help
  • Anonymous Apr 15, 2013
    ive got the same problem. what did you do to fix this?
    ive got the same problem. what did you do to fix it?
5 Related Answers
Anonymous
  • 4234 Answers
  • Posted on Jul 07, 2008
SOURCE: TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
James Colynuck
  • 40 Answers
  • Posted on Aug 31, 2009
SOURCE: my ps3 shows nothing but background waves, wont load main page
unplug PS3. Wait 10 minutes and turn on.
do the same with the power supply.
NemisizZ
  • 64 Answers
  • Posted on Oct 01, 2009
SOURCE: ps3 will not power up
i think you need to call sony to get this fixed. :(
Anonymous
  • Posted on Oct 01, 2010
SOURCE: stuck in the update loop with error 8002f1f9
I had the same problem... Just fixed it today..
Just before I had the update loop problem, my bluetooth on the PS3 went. I could only use the controller whilst connected to the USB port.
I replaced the bluetooth/wifi board
Anonymous
  • 8546 Answers
  • Posted on Jan 04, 2011
SOURCE: I have the Sony BDVE770W Theater System and I have
Try sourcing your TV audio from whatever source IT is watching, usually the cable box.
The audio works fine but the screen is incomplete and is frozen
Try performing a soft reset or a hard reset to the unit.
The soft reset is done by holding down the power button for at least 10 seconds and allowing the unit to power back on.
A hard reset is done by pressing and holding the bottom right hand corner of the screen while the power is off and then pressing the power button on. A pop up will appear asking to confirm the reset.
The hard reset will erase the user data, so it is advisable to save the data if possible.
Installing and running the Garmin WebUpdater to load or reload the latest update will resolve most issues.
download the latest version of WebUpdater software
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
2helpful
My xbox 360 hard drive keeps freezing, at times it shows its not there, and then there are times it wont let me access it. Its a 120gb hd
Hello
1 overheating can cause this.Relocate x box and clean/blow out dust and dirt with a can of compressed air.
2 Disc error. Disc is scratched or something is on it.Use windex and a paper towell to clean.Then wipe with some pledge furniture polish.Might work again.
3Check there are no incomplete updates waiting to be downloaded,if so finish them.
4 Hard drive getting full.Delete any cache or unwanted info on hard drive.
When i try to take my Xbox online to download maps for my game it says i need an update downloads update gets to the applying stage and then freezes
  • 1) Turn off your Xbox 360 and physically disconnect it from the internet by either unplugging the ethernet cable or disconnecting the wireless adapter.
  • 2) Turn on your Xbox 360 and sign into your account. You should NOT be connected to Xbox Live.
  • 3) Navigate to the "System" blade and choose the "Memory" option, then select your storage device.
  • 4) Now search. Look through all the system folders then find and delete ALL incomplete content files. You can spot an incomplete file by the yellow exclamation point icon. Remember to delete ALL incomplete files
  • 5) Once all the incomplete content files have been deleted, turn off your Xbox 360.
  • 6) Reconnect your Xbox 360 to the internet by plugging back in the ethernet cable or wireless adapter.
  • 7) Turn on your Xbox 360, connect to Xbox Live and hopefully your problem is solved.
A few days ago I had to restore my Playstation 3 system because it would not start up properly. Now I am having a problem downloading my game. I thought I had already downloaded the game to the PS3, but...
I would suggest that you take out your PS3 Hard Drive and reformat it as it seems it is having issues writing the updates to the hard disk. Also if you are using a wireless connection, it might be sending incomplete packets or no packets at all causing a corrupt update, so if possible plug your PS3 directly into the router.
Roads dont show up after downloading map updates
The download did not go correctly. You have a unit that is
missing or has incomplete files. Contact Rand Support and they will send you an
update card. It will not delete your user data and it will upgrade you to the
current version and with new maps. Be sure to have the serial number off the
back of the TND (bottom right) handy.Thanks Mark, Rand Lead Beta Tester
THE UNIT WILL NOT TURN ON
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
1helpful
On my Dell Dimension 3000 using Win XP it refuses to install properly. Went to Canon Help Line but their ideas have not worked either. Changed USB leads and sockets - not working.
Canon Help Line couldnt fix the problem. I tried installing on another Dell 3000 with the same result - incomplete installation. This looked like a Dell problem - so I went to Dell web site and downloaded about 10 System updates, including a Flash Bios chip.
After re-booting I turned off all Anti-Virus and Firewall, and guess what? It loaded and installed like a dream.
Printer now working fine!
2answers
Acer 4420 Notebook does not see Linksys router
Try hard reset of the router and reconfigure it
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
