SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: Changing the battery for my Fossil Watch
You have to have a tool to unscrew the back of the watch. I figured this out the hard way. I suggest taking it to a jewler for after I replaced my battery, the stinking thing still did not work. This sounds like a commom problem as I read more about them. Hope this helped.
SOURCE: changing the date
Which Fossil do you own?
Analog Date Watch:
Date Setting
Analog Automatic:
Time and Date Setting
Analog Digital:
Time and Calendar Setting
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
SOURCE: Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
