Paslode with no spark could be one of a couple of things. First, is the tool clean? These tools are notorious for failing due to the amount of sludge that builds up inside the tool from use. If you are cleaning the tool yourself, you should make sure the wires leading to the fan unit are not getting kinked or pinched during reassembly. Lastly, the tool needs a new spark unit. One way to test this out is to remove fuel and get ear close to rear of tool for a test shot. If you hear the click of the spark plug then the spark plug is fine and chances are that this tool needs to be cleaned.
SOURCE: paslode angle finish nailer the fan wont run
have had the same problem! started with a noisy fan then a non responsive one. try taking out the fan assembly as per service and drop a couple of paslode lube drops along fan shaft and gently compress fan to lubricate bearing, may not be a lond term fix but hasnt stopped since and that was over 2000 2inch ago. good luck.
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
-]0]0-
with them.
If
Paslode
heatman101
'll
with them.
If
Paslode
heatman101
Check the manual for the adjustment..
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
