Hi, I made a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
SOURCE: Where can I find an Jura Capresso Impressa F9 replacement lid
The only sources I have been able to find are in Europe. They do not always wish to ship to the US however. In the US the dealers always want the repair, but seldome wish to sell parts outright. Try this website for parts.
Mike
www.juraprofi.de
SOURCE: water will only dispense out of the frother.
It could be several soutions to this problem. First of all, try to clean the sieve in the brew unit, it may be clogged. Take out the tray, in between the 2 brown "lips" inside you can put your finger up and clean out all the old coffeegrounds stuck up there. Then put everything back in place and run a Rinse machine operation.
If this is not helping, listen out when you start up the machine; You should hear that the valve is turning 3 times, if it doesn`t it can be a problem with this valve not opening in right position. Then all the water would go out in the tray, and not into the brew unit. That maybe can be solved by changing this Multi ceramic valve or the Main Electronic board. Then it`s a job for a sertified Jura technician.
SOURCE: jura capressa imprezzo z5 coffee machine, did not
return to service centre this one's a *****
