SOURCE: logitech wireless mouse and keyboard
It is rare that the reciever goes out with these although not impossible so keep that in mind. But you can try to re-install the drivers for the usb which is what i was going to have you try first. If that does not work you can then try to re-install the software for the keyboard and mouse again. If it still does not work and you are sure all the batteries are good then it is time to replace the reciever. Though you will have to order the reciever i am fairly certain it will probably be easier and maybe cheaper to replace the k/b and mouse deplending on the model you have of couurse
SOURCE: My computer power up but
You need to check the RAM memory. For that open back cover of cpu then on motherboard you can see RAM memory reconnect it to motherboard .Pull cmos cell from motherboard for 10 minutes reconnect all connection again inside the cpu.Make sure motherboard it not ground with cabinet cover. Then check.Reconnect PCI card or vga card if any. Let me know if you need further assistance. Thanks for using FixYa.
