Maytag skybox stopped cooling
I just replaced my in-pieces starter relay and thermal swich with a Whirlpool 4387535 kit. My Skybox has been working fine ever since.
Note I had the same symptoms as other posts of the compressor turning on/off continuously (but no cooling)...I believe what was happening is that the starter relay would allow current to flow to initially start the compressor, but would never stop providing current to it after it had already started (as it should) thus in a few seconds the thermal switch would sense this and trip / remove power to the compressor...then this cycle would start all over once the thermal switch cooled down again and let power back to the compressor...
This kit is evidently the newer style of what is on the original Skybox compressors (functionally speaking)...the new starter relay looks and installs like the old one, but the thermal switch is different and you need to remove the old one (follow the black wire on the top post of the compressor back a little to a small black round thing with a flexible metal piece inside). The good news is that once you remove it, it already has the correct spade lug on the wire to plug directly into the new thermal switch which sits right on the top lug of the compressor above the starter relay.
Note I'm not a service tech, just a Skybox owner who was/is tired of Maytag disowning this product and calling it a "throwaway" when any part of it stops working (and all local authorized service centers laughing when asked to repair one).
Continuing on with my rant a little, I also see other posts on the internet which also state "throwaway" when you actually have a bad compressor because you can't get direct replacements anymore - my friend who does AC work on the side said he most certainly could put another compressor in there from probably just about any other mini-fridge...he just noted that it is a small place to do it so the replacement compressor form factor will have to be considered. He stated you may get a little more or less cooling efficieny but who cares if you really want to keep your machine working that you can't buy anymore (nor get a close alternative).
dispenser and lights work, does not cool.
I went to the web site you suggested, entered the info and unfortunately there is no listing for the starter relay or starter relay overload. Any other suggestions? Thanks in advance for your help
The Skybox has stopped cooling. There was some water below the unit when we noticed it had stopped cooling. Is there anything we can do prior to calling a repair person? We have no manual.
Thanks so much in advance---
I TOO HAVE A MAYTAG SKY BOX FOR ABOUT 5 YEARS NOW. THE COOLING SYSTEM JUST WENT A FEW MONTHS AGO. I HAD A MAYTAG REPAIR MAN LOOK AT IT AND HE SAID THERE HAS BEEN MANY PROBLEMS WITH THE SKYBOX AND THEY DON'T CARRY THEM ANY MORE. WHAT CAN I DO TO FIX THE COOLING SYSTEM
