Computers & Internet Logo
Posted on Feb 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello my computer will not connect to my screen anymore. I have a LG lcd monitor and tv it was working yesterday wen i turned it off and 2day wen i turned computer on my screen won't get the signal. Any solutions to a problem it may be or what might be broken
Michael Green
Level 3:
  • Master 3,799 Answers
  • Posted on Feb 02, 2012
Michael Green
Master
Level 3:
Answers
3799
Questions
0
Helped
599825
Points
10177
Check the cables and if this doesn't work try a different screen. In the event that a different screen does not cure the problem you may have bigger problems. It could be Ram failure it could be Graphics card failure or it could even be HDD failure. Always try the easiest and cheapest bits first.
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
1helpful
I replaced power board for a Samsung TV model #UN40F6300AF installed today. TV still turns off. If i turn the the TV on 5 or six times the tv will work fine. Any other suggestions on what to replace
Hello, I have a lg lcd monitor. w1941s model. when I start my computer, it work for sometime. then it goes blank showing only the LG logo. then the power button doesnot work. it hang up glowing. again
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
My Monitor LG Flatron W2243S keeps flickering and turns off, this started yesterday
Try another good monitor, if it solves the problem replace the monitor if not replace the computer.
1helpful
2answers
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
1helpful
2answers
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
2helpful
Screen dont work
Try pointing a torchlight sticking to the screen and see if you see a dim picture, in that case you have a faulty inverter.
Otherwise can be the controller board or power supply.
Grand Canyon Tech
Grand Canyon Tech
