Well, hate to say this friend ... but sending it to the repair centre would be the best and the only option to resolve the issue.
All the codes given above are not for the unit and there is no way you can reset the units using the remotes.
Thanks
Proton
Ok, here is solution to enter security code in Kenwood.
1= Press >>| key for 5~6 seconds while pressing [Auto] key. Display will show CODE - - - -
2= Press remote [5] key 2 times, display show K, now press >>| key
3= press remote [2] key 3 times, display show C. now press >>| key
4= Press remote [2] key 1 time, display show A, now press >>| key
5= Press remote [7] key 2 times, display show R, now press >>| key
6= Display will show APPROVED and job is done.
Let me know out comes :)
See the manual for the code
There are some reported cases of Kenwood units going into "PROTECT" mode when the main power was interrupted. These are traced to firmware and the main reason for the feature, security. There are four (4) possible ways of re-establishing operation of the unit by inputting the code:
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Hi again,
I understand. Additionally:
have you tried a"reset"?
pls try reference this page.
Sorry about the weird post.....my issue is the second part (after the email address). thanks.
Yes, I have the manual.
Thanks for the help, unfortunately none of those worked. I checked the manual and packaging for a sticker but no dice. The only sticker was the "Certified Upgrade" sticker on the box (this means that someone other than me has powered it on at some point). I also tried the 3 codes suggested (along with all of the other obvious ones) with no luck.
When I contacted Kenwood, they said to ship it to a certified repair shop. I am hoping that is a last resort, that is why I am here. Thanks.
I have tried all the basic codes, 0000, 1111, ......., phone numbers, etc... so it is obvious that I did not set the feature up because I have only a handful of 4 digit "pins" I would have used. I even tried a series of numbers I found on the box and in the manual with no luck. Keep offering suggestions! thanks.
Anyone have any other ideas?
The code is not in the manual. See the other comments above.
Sounded promising, but there is no "AUTO" button on the unit or on the remote.
Shipping it off to a service center is a last resort, that's why I am on this site.
